Toyota Supra JZA80 (commissioned build)
iceracer1
10-31-2012, 01:51 PM
Last week a girlfriend of my asked me to build her boyfriend's car. (which is also a friend of my).
I said yes, cause he drives a very very cool Toyota Supra JZA80 with 700bhp. He imported it from the UK a while ago.
Here are some pics:
http://modelbrouwers.nl/media/albums/245/6835/referentie%20(4)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/referentie%20(3)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/referentie%20(11)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/referentie%20(14)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/referentie%20(12)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/referentie%20(10)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/referentie%20(7)%20(Custom).jpg
Last weekend I bought the Tamiya Toyota Supra Castrol which was the best base I think. The bodykit is pretty much the same (sideskirts and wheelarches). It hasn't got on engine but if I combine the normal street Supra and this kit, the project will be too expensive. So this was the best I think. The Castrol wheels are also pretty close to the real wheels, which is good cause I don't have anything else that look the same.
http://modelbrouwers.nl/media/albums/245/6835/inhoud%20(1)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/inhoud%20(2)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/inhoud%20(3)%20(Custom).jpg
The bodykit needs a lot of work, so I started with the hood. First I filled up every airintake that I don't need. Then I started on the big airintake in the center of the hood. I used the kit supplied airintake, but I didn't used the whole part, cause I need the other half for the smaller intakes that I still need to make.
http://modelbrouwers.nl/media/albums/245/6835/ruwbouw%20(1)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/ruwbouw%20(2)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/ruwbouw%20(3)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/ruwbouw%20(4)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/ruwbouw%20(5)%20(Custom).jpg
Meanwhile I'll continue on the hood cause it needs a lot of work. And in my mind I'll try to find a solution to modify the frontbumper.
Kris.
Here are some pics:
Kris.
GvEman
10-31-2012, 04:20 PM
Looks good here as well ;)
iceracer1
11-04-2012, 05:26 AM
Meanwhile I got a little further with this project:
First I cutted out the other two smaller intakes and puttied everything again. I also filled up the old intakes in the frontbumper. I used Tamiya Epoxy putty for that cause it will be rock hard.
http://modelbrouwers.nl/media/albums/245/6835/bodywork%20(4)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/bodywork%20(3)%20(Custom).jpg
When the epoxy putty was fully dry, I could sand it smooth and measure the new intakes and drill/cut them in shape. I finished 1 side first.
http://modelbrouwers.nl/media/albums/245/6835/bodywork%20(2)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/bodywork%20(1)%20(Custom).jpg
Yesterday I did the other side of the frontbumper. It's hard to get it the same as the other side, but I think I managed it.
I also started to cut the other intakes. Between the putty layers I sprayed some primer to see the results so far, but I got some ghostmarks every time were I puttied. I think I need some spray filler to get it right?
http://modelbrouwers.nl/media/albums/245/6835/bodywork%20(5)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/bodywork%20(6)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/bodywork%20(7)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/bodywork%20(8)%20(Custom).jpg
Kris.
Kris.
rallymaster
11-04-2012, 06:59 AM
That's work like I love !! :thumbsup:
This build show us that you're as much skilled to convert a model as you are to paint it !!
What kind of car is the real one, a drift car...? That's a great yellow beast !!
iceracer1
11-04-2012, 12:13 PM
Thanks Phil. I think it's more a time attack racer but I am not sure about that. He plans to do time attack races when everything works again.
I also want to ask you.if it's possible to help me with the licenseplates again.
Kris.
Kris.
rallymaster
11-04-2012, 01:42 PM
Kris.
Of course, if I can help I will do the license plates. Do you still have my email to send me the expected plates sizes ?
OK, seem more logical to be a time attack racer even if it would also be a killer in drift races. :icon16:
Kris.
da_ashman
11-04-2012, 05:21 PM
Awesoem Looking Supra! & youve def got the skills to turn the Castrol Racer into your friends ride!
iceracer1
11-06-2012, 11:12 AM
Today I had a lot of time for this project reserved.
While I was very busy with the body, the mailman arrived and got my package fron Denmark. Thanks Mads for the dashboard and midconsole!!! I immidiatelly glued the rollcage together and modified the dashboard to fitt in the rollcage.
http://modelbrouwers.nl/media/albums/245/6835/primer%20(1)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/primer%20(2)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/primer%20(3)%20(Custom).jpg
Then I got further with the bodywork. I sprayed a layer of filler on the body, and some inperfections showed up. So it means more putty and sanding.... :D
http://modelbrouwers.nl/media/albums/245/6835/primer%20(4)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/primer%20(5)%20(Custom).jpg
And with the final layer of filler it was smooth enough for me.
http://modelbrouwers.nl/media/albums/245/6835/primer%20(6)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/primer%20(7)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/primer%20(8)%20(Custom).jpg
Now it was time to add some Zero Primer on it.
http://modelbrouwers.nl/media/albums/245/6835/primer%20(9)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/primer%20(10)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/primer%20(11)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/primer%20(12)%20(Custom).jpg
I also primered the wheels and painted them Jet Black when they were dry.
http://modelbrouwers.nl/media/albums/245/6835/primer%20(13)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/primer%20(14)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/primer%20(15)%20(Custom).jpg
Next on the list is paint the body in yellow :D
Kris.
Kris.
drunken monkey
11-06-2012, 11:16 AM
old school body mods.
don't see much of that these days with resin trans-kits being so popular.
iceracer1
11-08-2012, 01:44 PM
Yesterday I painted the body in Fayence Yellow. But it was not the right color. So I had to paint it with an other yellow. I found a used spraycan in my hobbyroom but it was not enough to spray, only when I spray it with an airbrush. So I need to decant the paint. Here's a little how to:
http://modelbrouwers.nl/media/albums/245/6835/geel%20(1)%20(Custom).jpg
Be sure the plastic foil is tight on the bottle:
http://modelbrouwers.nl/media/albums/245/6835/geel%20(2)%20(Custom).jpg
Then I cutted a pipet to fit on the spraytip.
http://modelbrouwers.nl/media/albums/245/6835/geel%20(3)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/geel%20(4)%20(Custom).jpg
And spray in the bottle:
http://modelbrouwers.nl/media/albums/245/6835/geel%20(5)%20(Custom).jpg
And then let the paint gas out for at least an hour.
http://modelbrouwers.nl/media/albums/245/6835/geel%20(6)%20(Custom).jpg
Now the yellow was still not good enough. I only had a bottle of Revell 12 Yellow and Tamiya Flat Yellow. I decided to go for Flat Yellow.
http://modelbrouwers.nl/media/albums/245/6835/geel%20(7)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/geel%20(8)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/geel%20(9)%20(Custom).jpg
Tomorrow I'll clearcoat it.
Kris.
Kris.
corvettekid_7684
11-08-2012, 10:48 PM
Really nice work so far!
ChristopheB
11-09-2012, 11:58 PM
Impressive skills. Can't wait to see more.
iceracer1
11-10-2012, 06:58 AM
Yesterday I clearcoated the body with 2K Clear from Zero Paints.
http://modelbrouwers.nl/media/albums/245/6835/blanke%20lak%20(1)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/blanke%20lak%20(2)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/blanke%20lak%20(3)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/blanke%20lak%20(4)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/blanke%20lak%20(5)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/blanke%20lak%20(6)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/blanke%20lak%20(7)%20(Custom).jpg
Now I go further with the chassis and interior.
Kris.
Kris.
MidMazar
11-13-2012, 08:44 AM
More scratch building then we usually see from you. Stunning progress.
iceracer1
11-17-2012, 10:56 AM
Last week I polished the body. There were a few dust spots in the paint that I sanded away. After some different polishing compounds the body is shining again.
Now I masked of the body to paint the lights and window rubbers.
After I removed the tape I need to do some touch ups and I could add the lights.
I also added black mesh on the air intakes.
http://modelbrouwers.nl/media/albums/245/6835/raamrubbers%20(1)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/raamrubbers%20(2)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/raamrubbers%20(3)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/raamrubbers%20(4)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/raamrubbers%20(5)%20(Custom).jpg
Now I'll get further with the chassis and interior.
Kris.
Kris.
ChristopheB
11-19-2012, 12:02 AM
So far it looks better than the real one!
Are you going for an exact replica? I am asking because I noticed that your front bumper is not damaged and that the wing attachment on the trunk is different.
iceracer1
11-19-2012, 03:45 AM
No it won't be an exact replica. The interior and chassis will be build box stock and the body must be the eye catcher. I know about the wing attachment, but the wing I use is a bit different. The damage on the frontbumper is already fixed on the real Supra :)
Kris.
Kris.
iceracer1
11-23-2012, 05:56 AM
Last week I spent some time on the chassis. I did some cutting before it fitts, cause it stucks to the new airintake in the hood. Then I could paint it and assemble it.
I added some cigarettesfoil on the exhaust area and painted the exhaust with a metalizer paint and polished it. The exhaust tip is made of aluminiumtube and polished.
I also added an intercooler so it will be visible behind the bumper.
http://modelbrouwers.nl/media/albums/245/6835/chassis%20af%20(1)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/chassis%20af%20(2)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/chassis%20af%20(3)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/chassis%20af%20(4)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/chassis%20af%20(5)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/chassis%20af%20(6)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/chassis%20af%20(7)%20(Custom).jpg
Now I need to finish the interior.
Kris.
Kris.
iceracer1
11-25-2012, 08:52 AM
The interior is also finished. I kept it simple, but I used the standard Supra midconsole and dashboard that Mads sent me. (Thanks again mate!!)
The seats and dashboard are painted with Tenco Proto structure paint.
http://modelbrouwers.nl/media/albums/245/6835/interieur%20(1)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/interieur%20(2)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/interieur%20(3)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/interieur%20(4)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/interieur%20(5)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/interieur%20(6)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/interieur%20(7)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/interieur%20(8)%20(Custom).jpg
Meanwhile it's finished. I only need a licenceplate, but I have to wait for Rallymaster (Phil) when the decals are ready.
Kris.
Kris.
ChristopheB
11-25-2012, 09:51 AM
Excellent work!
da_ashman
11-25-2012, 05:21 PM
excellant work as always!!!
iceracer1
11-26-2012, 12:06 PM
I just forgot to add the bonnetpins, side indicators and the rear towel hook so I had to get to the modellingroom and add them to the model. The bonnetpins are from Scaleproduction, the indicator lights are from a left over kit, and the towelhook is scratchbuild.
http://modelbrouwers.nl/media/albums/245/6835/laatste%20loodjes%20(1)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/laatste%20loodjes%20(3)%20(Custom).jpg
http://modelbrouwers.nl/media/albums/245/6835/laatste%20loodjes%20(2)%20(Custom).jpg
Kris.
Kris.
andybmw7272
11-26-2012, 01:23 PM
Very nice Kris!
I would say you nailed it!
Andy
Andy
MidMazar
11-26-2012, 07:21 PM
Your scratchbuilding skills have improved so much!! Excellent build, the person getting the model will be ecstatic when they recieve it. :thumbsup:
BTW the SP vento is being released soon!!
