P1130
mno221
10-02-2012, 03:58 PM
Ok guys i have a CAN OBDII scanner, these are the reading when i hook the scanner up:
MIL Stratus - OK
Misfire monitor- OK
Fuel system mon- OK
Catalyst mon- OK
Evap system monitor - INC
Oxygen sens Monitor - OK
Oxygen sens HTR - OK
EGR system - OK
With that being said what can be causing code P1130, I've replace the oxygen sensor on the driver side before the cat still nothing. Help
j cAT
10-02-2012, 05:31 PM
MIL Stratus - OK
Misfire monitor- OK
Fuel system mon- OK
Catalyst mon- OK
EGR system - OK
swap O2 sensors see if the code changes. Is this the only code ?
check the fuel regulator for leakage into the vacuum line.
this sensor gets wiring damage because the wire to it was not proper secured.
mno221
10-02-2012, 08:58 PM
j cAT sorry for mis-type the code is 1133 not 1130, i replaced both up stream sensor and fuel regulator back in March this year, and the code came back right afterward, so I replace the drive side up stream last Friday thinking it may be defective, drove all weekend and it came back today. On the same note yesterday i drove through carwash and as i was going through the dryer the service engine light started flashing.check it and code P0300 misfire on the drive home went away, today P1133 came back.
Thanks in advance.
j cAT
10-03-2012, 07:40 AM
Thanks in advance.
The cause for this code is not enough O2 output switching. bad wiring / connectors at the PCM /exhaust leaks / etc.
with the car wash incident your wiring could be messed up.
also check fuses especially the O2 heater fuses/sockets for security.
people wiggle the fuses for removal. this damages the socket.
remove the under hood fuse box from fender, check those wires and connectors under there for damage [rodents]
