1997 ford crown vic police interceptor
pdj54
08-27-2012, 11:38 PM
went to a picnic thday before yesterday and everything was fine..I parked my car and when 4 hrs later I started it to go home and lo and behold i could barely steer it....that quick!..its driveable on ststraightaways but a bear on sharp turns..I checked the fluid..its full..no noise from pump..i checked relay behind glovebox and its plugged in ok.....WHAT NEXT!
i HAVE ALSO SPRAYED PB BLASTER AND WD40 ON THE STEERING KNUCKLE THINKING MAYBE THAT GOT STIFF ON ME..NO DIFFERENCE
way2old
08-28-2012, 05:13 PM
Sounds like you might have broken the shaft on the steering pump. Take the P/S cap off and see if the fluid is moving rather quickly. If it isn't, take the belt off and see if the pulley is really easy to spin.
