78 150 engine swap
kaqbot
08-24-2012, 06:12 PM
hello
im struggling to restore a 78 150 custom,it has a bad rod in its 302,i do however have a 1980 302 with trans as a donor it came from a 80 linclon town car,the 80 302 has alot of emission stuff, that is making me think this isnt gonna work,throttle body type carb o2 sensors on the headers air pump ,i didnt want it to get away it only has 80,ooo miles on it
the 78 302 has a 4barrel carb i dont belive belongs on it ,but it runs
any ideas and advice very welcomed
thanks mike
oldblu65
08-27-2012, 01:33 AM
hello
thanks mike
The later model 302 is fuel injected and would require all the wiring loom , sensors , electric fuel pump , and all associated emissions equipment be used to have the engine properly operate . I'm not a Ford engines expert but you " might " be able to use the short block from the newer engine and incorporate your earlier manifolds , carb , etc. ? Like I said , I'm no expert so I can't say for sure it would work ?
big white bufflo
08-29-2012, 05:44 PM
remove the intake and put yours on .you might have to replace the cam because it wont have the fuel pump cam lobe on it and the fire order might be diffrant that all i can think about oh and the oil pan but it will work no worry on all the emission junk
kaqbot
08-29-2012, 06:33 PM
all advice welcome thank you
