Intake Manifold Gasket Appears OK
98GMCpickup
08-24-2012, 10:05 AM
Hi , I removed the intake manifold and there was no real evidence that the gaskets were the problem. Is there any way to know for sure? Should I go into the heads?
gmtech1
08-24-2012, 10:57 AM
What is the issue you are trying to fix?
98GMCpickup
08-24-2012, 01:26 PM
Coolant going into crankcase. Does that prove it is the intake gasket leaking?
gmtech1
08-24-2012, 03:46 PM
That is the most LIKLEY reason for coolant in the crankcase. Worst case would be a cracked block.
98GMCpickup
09-01-2012, 07:30 AM
Hi, I am having big problems in trying to make this truck run. I have found top dead center as best I could. It starts after I mess with the timing, but it revs up really fast for about 3 or 4 seconds and then stops. Did I miss TDC?
