turn signal problems
temperingloser
07-17-2012, 01:50 PM
Just wondering if anyone could help me with this situation. I have no turn signals expect the back drivers side that is the only one that works there is one bulb on the passenger side that will not light up and I have no power to it is the side marker white bulb I replaced the flasher because none would flash at all now it is just the back one. Not so sure where to start because I never experienced this problem before on this car and cant seem to find anything I am looking for.
thanks
nathan
thanks
nathan
HotZ28
07-17-2012, 05:52 PM
Any blown bulb, or bad socket in the turn signal circuit will cause a malfunction. Check all bulbs and sockets.
temperingloser
07-18-2012, 10:01 AM
alright all bulbs will light up but the only set that will blink is the rear driver side i was thinking it might be the blinker switch in the steering column but was not sure I checked every single bulb and wires only to find nothing at all. I also have the indicator in the car above the rearview mirror and none of the lights are lit.
Jsaw
07-18-2012, 10:15 AM
I would take a look at the signal switch. If you check the sockets and bulbs and they are all okay this would be the next best guess. What model vehicle are you having the problem on?
-Jsaw
-Jsaw
temperingloser
07-18-2012, 10:48 AM
it is a 96 park avenue ultra
HotZ28
07-18-2012, 01:42 PM
Do all bulbs flash using the emergency flasher? Do the brake lights work with foot on the pedal? Are all side marker and front/rear lights on with park light switch made?
temperingloser
07-18-2012, 02:32 PM
everything works correctly with the emergency flashers and all bulbs are good the brakes light work too and all of park lamps work when turned on
HotZ28
07-18-2012, 10:38 PM
If everything else works, more than likely the column switch is not doing it's job.
temperingloser
07-19-2012, 04:06 AM
Thanks a lot I will order the switch today and install myself and post back results
Jeff Collision
07-19-2012, 05:55 AM
Check your fuses and make sure that the circuit is complete. Then you can check the flasher, change if its need. Also check the power to the fuse and light socket.
