Polarity on a 1994 Plymouth Voyager
jamesslcx
03-15-2012, 03:31 PM
Hello all, my little brother has a problem with his van 93 Voyager 3.3. I removed his negative cable to check for a draw and I happened to also hook up the test light to the negative post and then to the negative battery to ground terminal the test light lit up! I don't think this is normal for even a Mopar product. By the way one of his complaints was a spark when he tried to connect the negative terminal to the battery. Any thoughts would be appreciated.
jpb53
03-15-2012, 04:49 PM
The sparking is normal all the modules need power. Ck this link for parasitic draw test if that is your problem.
http://www.popularmechanics.com/cars/how-to/repair/how-to-stop-car-battery-drains
