03 trailblazer trans swap interchange from 02 blazer??
bjrjr16
02-20-2012, 08:44 PM
Hi my friend has an 03 tb and the trans went, shows its a 4l60e same one that is in my 02 parts blazer. i was wondering if anything was the same? is the transmission body the same? can i change the bellhousing off the old trans onto my blazer one? according to the cross reference it a 4l60e and its a envoy/ tb only. but is it only because of the housing? thanks alot for any help, it is greatly appretiated!
maxwedge
02-22-2012, 03:17 PM
The pcm programming may be different as well as the driveshaft yokes, check with a salvage yard for interchange info.
bjrjr16
02-22-2012, 11:19 PM
yokes are located on the transfercase tho. hopefully the body is the same
