help 3 cylinder has rough idel after rebuild
ipjkcu
11-24-2011, 05:03 PM
hey all hehe happy t-day. so probley going on 8,000 on rebuild and it is starting to have a really rough idel. it always seemed rough but is getting worse. i did a full rebuild. pistion/rings oil pump,water pump t-belt,and tensioner, bearings and all new vavles intake and exhuast. and iam sure iam messing something. oh and rebuild the 5 speed, but iama little lost on this idel. help please ask a question i well try to respond with what i know. oh p.s my g/f drive the car. so it yea.. umm not the best of driver
Crvett69
11-25-2011, 09:21 AM
might want to run a compression test on engine to make sure all the cylinders are still ok. have seen fresh rebuild burn valves on new heads
brivers
11-27-2011, 07:45 PM
Little more info needed. Like, did it ever run good? Does it smoke? Are you sure about timing belt installation and distributor timing? Does it start easy? Does it run hot or cold? Does the motor shake more than normal?
( as to crvett's comment: cmon man, are all the holes still ok)
