2003 Lumina LS doesn't have dashboard lights
junmer
11-06-2011, 02:27 PM
All other lights work except for the dashboard lights which makes it difficult to drive at night. Any ideas to resolve this problem? Thanks.
JUNMER
JUNMER
Schurkey
11-07-2011, 09:05 AM
1. Check the dashboard dimmer control.
2. Check fuses.
3. Check power and ground at the dash.
2. Check fuses.
junmer
11-07-2011, 09:45 AM
Thanks, Schurkey. Where can I find the dashboard dimmer control? Fuses are perfect.
JUNMER
JUNMER
Schurkey
11-07-2011, 11:30 AM
JUNMER
Don't know about an '03, my '92 and '93 have a slider next to the headlight switch.
JUNMER
gmtech1
11-07-2011, 12:26 PM
The 2003 Lumina was an export only vehicle. Going to be tough to find info on it here in the States. I recomend you look locally for some information
maxwedge
11-07-2011, 12:40 PM
Nice catch.
Nice catch.
junmer
11-07-2011, 03:25 PM
Oh yeah, Schurkey. I found it, but it seems the car wash boys have damaged it. Found the slot for the slider but the slider itself is missing. Tried to poke it with some sharp object but there's no response from the lamps. I don't want to take it to the agency as they surely will let me buy the whole assembly of the dashboard. Not sure if I'll learn to live with it.:shakehead
maxwedge
11-07-2011, 07:50 PM
The dimmer itself is easily replaced, it is an easily accessable component.
junmer
11-08-2011, 10:57 AM
Thanks Maxwedge, I will try to tinker with it and hopefully can get the bulbs to light up. I don't believe they have burned down to be replaced.
JUNMER
JUNMER
jamesmetairie
12-09-2011, 06:42 PM
on my 1998 lumina the right half of the dash cluster is burnt out from the middle of the speedometer on thru the temp gage .the dealer and auto zone told me that the entire cluster must be replaced. the dealer said they send a cluster to a shop somewhere to be rebuilt.(?)
maxwedge
12-09-2011, 09:01 PM
The printed circuit is probably bad, there are several companies that do this on an exchange basis, google gm instrument clusters.
