'03 TB sway bar linkage
claytonduk
10-19-2011, 05:18 PM
My dealer said all 4 sway bars were bad(the little dog bones at each wheel). Does anyone know what size hex head socket is used to remove these. I tried a 7/32in but that had alot of play in it. so im thinking its metric. From what I've read Moog is the way to go for replacements. Thanks for any help as always!
gmtech1
10-19-2011, 05:25 PM
I'm not 100% sure, but I think they're 6mm. Good luck, they can be a real bear to remove sometimes.
claytonduk
10-19-2011, 11:46 PM
thanks gmtech1. gonna get me a set I think. from looking at my sockets 6mm is the next largest.
maxwedge
10-20-2011, 08:55 AM
Cut em off, you will break that tool when they are frozen from " north country" issues.
rubberman
02-15-2012, 10:05 AM
The OEM fronts were 7mm for me. 6mm was loose and 8mm couldnt fit. But the backs are 6mm.
Schurkey
02-16-2012, 08:52 AM
Huh?
ricebike
02-16-2012, 09:16 AM
:thumbsup:8mm was loose and 6mm couldn't fit.
fixed!
but OP said that 7/32" ~ 5.6mm and that's too big???
rubberman
02-23-2012, 02:07 PM
Huh?
I'm saying i bought a 7mm hex socket for the front end links. Perfect fit. But the backs take a 6mm hex.
After replacing the end links, make sure you tighten the nuts down real good plus use blue thread locker. I even used a nylon lock nut to double nut it.
MV1tech
04-09-2012, 03:07 PM
a little heat goes a long way..... just a touch of heat on the 18mm nut and a pair of vice grips will remove the nuts with little or no problem.
