Coolant & Misfire
Christophe Salvain
10-19-2011, 08:43 AM
Hi
The fact :
- 136400 miles on a '03 Venture.
- Run on 5 cylinder for 1 minute after crank. After run fine on 6 cylinders.
- Engine coolant is leaking but I dont know where : there's no smell like a defective IMG.
I get a noticable "P0304: Misfire cylinder #4" with CES blinking under accelerating.
The cylinder #4 is the front middle one : the easiest to check and access.
BTW i change plugs, wire and coil and still the same symptoms.
Any idea : fuel injector ?
Bst rgds
ps : All apologies for my poor "french touch" english :smooch:
danielsatur
10-19-2011, 12:58 PM
Do a compression test on cylinder 4 1st.
You can roll a fuel injector just like a bad plug, plug wire, or COP.
How's the coolant level?
Tech II
10-19-2011, 04:27 PM
Cylinders #1 and #4, are "companion" cylinders.....sometimes what looks like a problem in one cylinder, is actually in another.....the fact you are losing coolant, sounds like you are burning it up intermally....especially on a cold start....when you shut the vehicle down, coolant pressure, could add coolant to a cylinder, if you have a bad head gasket....on initial startup, you will have a misfire condition until all the coolant is burned out of the cylinder...if the problem gets real bad, the engine could hydrolock...
I know the code is for #4, but these engines are famous for a head gasket leak at #1 cylinder.....in the back on the passenger side...
What I usually do to confirm this, is pressure test the vehicle overnight, with a coolant pressure tester....next day, I disable spark and fuel....in your case remove #1 and #4 plug....have someone crank over the vehicle, and watch to see if coolant comes out of a cylinder....have never seen #4 be the problem, always #1....
Christophe Salvain
10-23-2011, 06:31 AM
Hi.
Thank you for advices.
Bad news : yesterday the head gasket blew up !
I was waiting at the gas station when the coolant suddently overflowed from the coolant reservoir.
Allmost 137km miles ... I dont know if this old engine deserves a new life ...
Rgds
Tech II
10-23-2011, 09:59 AM
Well, if coolant didn't get into the oil and just blew out the reservoir, and if you haven't been driving the vehicle causing an overheating condition, may get away with a head gasket job.....
Vehicle is 9 years old....if in good condition, tranny is ok, would be worth a head gasket job......remove both heads, and have the heads checked out(machine shop) for cracks and flatness...
Gets you a few more years driving it, eliminates new car payments for awhile, and then trade it in or sell it....
Christophe Salvain
10-24-2011, 06:09 AM
Mmmhhh I'll follow this way.
My 2003 is in very good condition, I think it worth it.
Thx
Christophe Salvain
11-04-2011, 09:36 AM
Thx
Hi
The engine is dead :-/
This minivan is in very good shape and condition.
I think it worth to replce the engine.
What do you think of that : http://www.rockauto.com/catalog/x,carcode,1410523,parttype,5240
Or http://www.newgmengines.com/12491872.html
Does anybody have a feedback about both engines ?
Rgds.
Christophe Salvain
11-14-2011, 03:03 AM
Hi
Rgds.
Hi again
Finaly my mechanic will change the head gasket.
Do you know the complete part list to achieve ?
- both bank#1 & bank#2 head gasket,
- water pump,
- what else ???
Thx
danielsatur
11-14-2011, 10:35 AM
I would consider Blue Devil, or http://www.steelseal.com
Scrapper
11-14-2011, 12:55 PM
Hi again
- water pump,
- what else ???
Thx
you do have a leaking head gasket or crack head or both? only other thing i can thank of where you say what else would be valve cover gasket and i would use rubber gaskets.
Christophe Salvain
11-14-2011, 03:44 PM
I tried Steelseal : it didnt work.
Duno if the head is cracked.
To be continued ...
danielsatur
11-14-2011, 08:04 PM
Make sure you get your money back from steelseal!
Head gaskets, head bolts, intake gasket, exhaust main gaskets, thermostat, water pump, and coolant.
See http://www.partsgeek.com
