2003 with P1516
jreiter2
09-28-2011, 12:02 PM
replaced the throttle body in my 2003 Chevy silverado yesterday evening and had no P1516 problems driving to work this morning. I did notice that the engine idles differently and was wondering if that had anything to do with "calibrating the throttle body" after replacement. I heard that you don't have to do this but if so, is there a procedure out there to follow?
shorod
09-28-2011, 12:48 PM
I moved this post to the appropriate forum.
-Rod
-Rod
jreiter2
09-28-2011, 01:53 PM
Rod, thanks for moving the post. I am a new member and have no clue how to submit a post in the appropriate thread.
j cAT
09-28-2011, 06:17 PM
this may be due to the old one being defective. disconnect the negative battery terminal for 15min then reconnect and after afew runs it should be good...
idle should be 600 rpm in drive. also the idle should not drop when turning wheels or ac compressors cuts in..
110% GM failure rate on the 2003 throttlebody drive by wire units..
jreiter2
09-29-2011, 12:58 PM
Thanks for the information. I will give it a try. By the way I made it in two days in a row without any errors. Very cool.
