Power steering pressure switch
Burt the Boater
09-24-2011, 03:36 PM
2001 Dakota - It started out as a whining noise from the power steering pump eventually setting a check engine light code. Ends up the power steering pressure switch mounted on the power steering pump hose was leaking. A 13/16 inch wrench and an oxygen sensor socket had the old one out and the new one in. Added a few ounces of steering fluid. It only took about 15 minutes.
Cheers, Burt
