malibu 3.1-just changed head gaskets. now it just cranks and backfires??
divotfreely
08-13-2011, 07:27 PM
2000 checy malibu 3.1 I just changed head gaskets. now it won't start. cranks backfires then dies. i have spark and fuel. compression is low around 120-130 so i think i have a vacuum leak to search for.
i have been dealing with this for the last day and think it is time to ask for guidance.
thanks for reading
thanks for reading
maxwedge
08-13-2011, 08:22 PM
Crossed wires?
divotfreely
08-13-2011, 09:20 PM
wish it was something that easy. no.
i started tearing back into it and was wondering how to injector o-rings are supposed to seat. the manual reads like they are merely compressed against the hole in the intake as opposed to actually entering the intake.
inafogg
08-13-2011, 10:36 PM
the o'rings are on the injector,when you install the fuel rail the injectors
will slide into the manifold (hole).make sure you lube o'rings. they will seat/seal inside hole via the o'ring.
how did engine run before? no sure if the 3.1 has differant intake/exhaust push rods. worth checking
divotfreely
08-14-2011, 10:02 AM
i have it down to where i can get the covers off so will probably go ahead and check the pushrods this morning- they are different sizes though i was careful to make sure i did not mix them up.
it ran fine before i changed the gaskets (other than overheating ).
every place has the fuel o-rings i bought as the correct replacements, though they seem larger than the ones i took off. maybe the the old rings just seem smaller cuz they are old? so i never had the new ones seated in the holes. THAT IS PROBABLY MY LEAK! guess i will coat them with oil and get them installed today. they just seem like they don't want to go in.
maxwedge
08-14-2011, 03:01 PM
Lite coat of vasoline will do it.
divotfreely
08-14-2011, 05:41 PM
tore back into it pretty deep today. i am thinking i had the rocker arms way over torqued to the wrong specs. would that cause the valves to stick and therefore misfire and not start??
maxwedge
08-14-2011, 07:14 PM
Got compression, you say so, so not a valve issue.
divotfreely
08-14-2011, 07:22 PM
if the valves were sticking compression would be 0 ? cuz i do have compression but it is pretty low.
maxwedge
08-15-2011, 08:12 AM
Could just be low from not holding the throttle open or low cranking rpms.
procaddytech
08-15-2011, 09:41 AM
The intake pushroods are 5 3/4 inches long and should have a yellow stripe.
The exhaust pushrod is 6 inches long and should have a green stripe.
If these get mixed up the long ones will usually bend. I would definately check this after the basic crossed wires. vacuum leaks etc. If the long rod got put on the intake and bent low compression could be a result. Bent pushrods will cause backfiring also.
