1995 K1500 EC - Rear drum brakes
tken35
07-24-2011, 09:40 PM
I took the rear brakes aparts, but I can't remember where the "green" circled item attaches to :banghead:. This is the lower half of the actuator spring.
Any help will be greatly appreciated and thank you in advance!
j cAT
07-24-2011, 10:04 PM
the picture you are using is not that good..find another gm brake JPG..
when working the drum brakes work one side at a time ,,that way you can use the side not worked on as a reference..
inafogg
07-24-2011, 10:40 PM
if its a small flimsy/weaker 1or 2 inch long spring it should go to #28 pin should have a slot in it,(outer edge) & #3 should have a notch in it right where the #3 arrow points.
or maybe to the acuator itself at adjuster wheel
or my memory sucks!!!@
