1996 350 =Best water pump?
hurtts789
07-21-2011, 11:56 AM
I have just replaced the fuel pump for the second time and will replace the water pump today. In an effort to not replace the water pump as often, what one do you all recommend? I will also be replacing a few hoses. Anything else you can add will also be appreciated.
Frankp87
07-21-2011, 12:53 PM
Can't go wrong with AC/Delco pump. I try to stay with original parts as much as I can.
If you're replacing the pump you may want to replace the thermostat and radiator cap as well.
