Lamborghini Murcielago LP640 Roadster - Versace
da_ashman
07-11-2011, 02:21 AM
Hi Everyone
This is my latest project that I just couldn't resist starting on.
Managed to pick up a Murc Roadster kit that had been half started a few months ago & then brought the Hobby Design transact, with a little bit of research I decided to build the Versace version.
There is limited & vague information available about this edition, 20 were made, mostly Coupes. Some websites say there were only 2 roadsters produced, 1 in white & 1 in blue (that had since had the versace bits removed)
But a quick search of youtube proves there are more.
Anyway on to the pics
The Car
http://i154.photobucket.com/albums/s258/da_ashman/862622.jpg
The Transkit
Amazing detail, the photoetched parts are amazing.
The resin in clean & smooth, almost no bubbles.
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0606.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0607.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0608.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0609.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0610.jpg
The incredible wheels
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0611.jpg
Most of the other bits
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0612.jpg
Hobby design supplies you with 3x carbon fibre engine cover things
The photos Ive found show different ones in different cars so I picked the one I liked the most, the bottom one
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0614.jpg
The Photo etch
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0615.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0616.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0617.jpg
These are the pieces for the brakes, nuts & the bolts that hold the hat together, pretty amazing detail, should built up nicely
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0618.jpg
This is the clear engine cover panels of glass, very thin. I wont be using these but thought I should show you.
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0619.jpg
The body as I got it, the previous owner had primed it without removing the mold lines. It was going to be candy green
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0620.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0621.jpg
I do love these wheels, as a bonus the roadster kit came with the original Murc wheels in shinney chrome too!!
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0622.jpg
This is the engine cover, I will be modifying this to have a glass panel in the middle
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0623.jpg
Oh wait, it doesn't fit.... By ALOT!!!! rear bumper has stunk 4mm!!!
Massive thankyou to Hobbyeasy for sending me replacement parts (twice)
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0395.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0397.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0398.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_0400.jpg
So a big warning to anyone buying this transact, make sure you test it against a plastic kit straight away & don't store it for too long!
Thats all for now, I have started cleaning & sanding all the resin parts & should have some pics for you soon
The Car
The Transkit
The Photo etch
ZoomZoomMX-5
07-11-2011, 08:59 AM
Will be watching this for sure. Locally there's a white Murcielago Spyder like the photo, just w/o the logo on the door.
There is just no excuse for undersized resin on very expensive transkits. NONE.
Whether it's built right away or stored, it won't matter...if it is the resin shrinking, and say it was put on the model before it shrank, it won't miraculously not shrink on the model...it will cause big problems.
I'm pretty sure it's the original molds that have shrank over time and with production. I've never seen issues like this in resin from the US, but w/Hobby Design and the resin in some of the Fujimi kits, it seems to be a definite issue.
BVC500
07-11-2011, 09:03 AM
Glad I was one of the first to buy an HD transkit. Very little shrinkage issues for me. Looking forward to your build!
RonCla
07-11-2011, 06:30 PM
I have just had the same fitting issues with the Hobby Design Hamann Fiat 500 trans kit. The front and rear fitted perfect but both side skirts were bent like a banana and were several mm too short.
The Hobby Design 722 SLR GT trans kit I've just got has a bonnet that is so twisted its unusable too.
There seems to be an issue with the resin Hobby Design is using as I've never seen a similar issue with any of the other manufactures resin parts I've had experience with like Hiro, S27, Fisher, Modelhaus, Replicas & Miniatures.
MidMazar
07-12-2011, 11:25 AM
Wow, i've never encountered such a bad t-kit even with the older fujimi/aoshima kits. They are soo much older than HD kits and not as bad. I agree, Hd better invest in some better resin. I was eager to buy a kit from them, not anymore. With so much money, id rather buy a scale production,scale motorsport or even a studio 27 kit.
Good luck on this build. The easiest way to make those parts to fit is cutting them in the middle and adding styrene in between until its big enough. But in your case it might take even more effort than that to make it fit.
rx7king
08-31-2011, 01:43 AM
is this HD kit the only mf making the LP640 tho? Also ash, how long did it take to get the replacement parts? I really want to build this but this scares me away a bit
countach79
08-31-2011, 05:56 AM
can't wait to see this one done!
auw12
08-31-2011, 10:59 AM
I also got this TK in the pile. Not just the resin parts, you might have to test fit everything from any sort of HD products, then you can be sure if you should go on or just quit. Best luck of this build.
da_ashman
09-04-2011, 08:35 PM
Hey, it only took about a week to get the first replacement parts & then about 2 weeks to get the replacement parts that actually fitted. & thats delivered from Hongkong to New Zealand
I think Hobbyeasy just sent me another set the first time that they had in stock & then when that turned out to have the same problem they got replacement parts from HobbyDesign so I guess thats why it took a bit longer & to Hobbyeasy credit they replaced the parts at no additional costs etc, so many thanks to them!
As for Progress, it has been s l o w .... To my amazement having a baby somewhat encroaches on hobby time! lol. I havent really done too much, I'm still working on the seats to get them smooth & have designed all the decals that I need to have printed, oh & ive manged to get the parts cleaned up & primered & ready for mounting to the body, but there is alot of modification to chassis parts & wheel arches etc to get the new body to fit! But more on that soon!
Ash
Ash
da_ashman
10-16-2011, 07:53 PM
Well, Finally made a bit of progress.
Started mounting up the new resin body panels, most still need a touch of work, some pieces like the fron bumber & side skirts require a small amount of lengthing to math the plastic body. There is also quite alot of other parts that need to be modified so that the new body can be mounted. the Rear wheel housing needs to be reshaped to fit into the new rear bumber, the chassis needs plastic removing to fit the side skirts & same with the front bumper.
Anyway onto the pics!!
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/10919489.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/490b8571.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/43821dc2.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/c79ba64a.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/fbce3718.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/ace71d64.jpg
Next I need to make the engine cover & make sure all the pe fits
rx7king
10-16-2011, 09:32 PM
So much work, keep it up!
Entau
10-16-2011, 10:52 PM
i wanted to get the HD lp640 transkit a while ago, but seeing no wip of the kit and tonnes of bad review, i dropped the plan :lol:
now i might change my plan, looking forward the progress and good luck on your conversion :icon16:
Ferrari TR
10-17-2011, 02:29 AM
Looks great.
Seems like a lot of work for an expensive kit. Hopefully the finished model will be worth the effort and expense. Good luck.
countach79
10-17-2011, 03:56 AM
lovin it!
auw12
10-21-2011, 03:40 PM
Nice progress, please do finish it! Have you test fitted the tail light cover? I was worried about the soft material HD used, it could have shrinking or fitting problems.
MidMazar
10-22-2011, 12:41 AM
Looking good, now a days there really is only a few places to get HD t-kits as most of them come shrunk and not everyone is willing to take back a return or send out a new one. Buyers beware!!
Keep us posted.
Keep us posted.
da_ashman
02-27-2012, 06:51 PM
Finally made a bit of progress with this one, I swear its fighting me all the way!
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/a1aa2be4.jpg
Had to sand the leading edge of the bonnet to sit flush with the bumper, despite adding 0.5mm styrene packers to lift the resin bumper to sit flush
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/60db9f81.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/a4425734.jpg
This was the most difficult part, trying to get the resin side skirts to line up & sit right the plastic kit, have spent hours sanding this to line up & now have deshaped the curve, so need to do some filling & then some more sanding...
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/0289fd9b.jpg
The new Engine cover
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/416f9546.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/71f4b104.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/360a8037.jpg
The Wheels! Damn Sexy! Not finished yet, missed a few areas with airbrushing Black, not the easiest wheels to paint!
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/e0476c89.jpg
So What makes this Versace Edition more special than any normal Roadster? The interior!!
The interior is fully clad in Versace Leather, The seats have the "greek" design embosed on them, the door trim & dashboard also have a black leather enbossed pattern to them (thats up next). Also came standard with the full Carbon Fibre interior bits from the Lambo options list
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/418a28f2.jpg
& Yes it currently is all painted gloss, it wnt be staying that way!
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/35f6fdd0.jpg
The Engine Bay Also gets the Carbon loving!
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/d5b7668b.jpg
Couple of other bits, Sorry for bad lighting, sun was fading
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/f205ee8e.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/f0f44a0f.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/ad925ea3.jpg
More to come soon, so many parts to modify to get the body to sit over the chassis!
Thanks for looking!
Ash
Thanks for looking!
Ash
corvettekid_7684
02-28-2012, 01:29 AM
Impressive work...I don't think I'd have the patience for it! Really cool build, I like the special upholstery
RonCla
02-28-2012, 04:28 PM
That Hobby Design trans kit is certainly testing your skills. It looks like you are on top of it though. Hobby Design have some great subject matter but i'm afraid their manufacturing quality leaves a lot to be desired
crisjr
02-29-2012, 07:00 AM
This is exactly what i think about HD .. I buy PE from HD with my eyes shut, but when we talk about anything resin made.. hmmm..
da_ashman
07-11-2013, 12:28 AM
Finally after a 16month hiatus the Versace is back
The side skirts have been the biggest problem & the reason it was shelved. But with a little motivation & some sanding time Ive managed to get her ready for paint.
Currently sitting in White primer ready for a gloss white coat, the decals are underway too, the photoetch is mostly bent reay for paint, the brakes will take awhile however theres about 30 parts to each!!!
Anyway the pics
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/21991830-C11D-40B5-9176-E9EFC2BBB623-2580-000004DAAE02D989.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/76B202BA-4CB4-4FB9-A84F-92E51F783970-2580-000004DAB243CC4A.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/239478BD-3657-408A-AF0F-B28C1437A9F0-2580-000004DAB5D33030.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/1BE4B1D6-B7CD-4524-88F2-9636459C1596-2580-000004DAB98F1B97.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/54778F28-0315-4D71-B93F-C340BBD92403-2580-000004DABD2A9BD8.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/E4CFA25D-3ECB-422C-9BD3-F6E3B4F6E120-2580-000004DAC1645D08.jpg
So hopefully progress will be somewhat more frequent as Id like to have this one done by xmas so hopefully I can convience the Mrs that i need to get Hobby Designs Lamborghini Murcielago 670sv !!
Ash
Anyway the pics
Ash
rx7king
07-11-2013, 12:59 AM
Looks great ash glad to see it back on the bench. I can't wait to get hobby designs SV also!
generationx
07-11-2013, 12:57 PM
This is looking really nice!
andybmw7272
07-12-2013, 12:05 AM
So glad to see this one back.
I was afraid someone was playing a mean trick and replying to an old thread.
Great subject!
Andy
Great subject!
Andy
bejonek
07-15-2013, 08:00 AM
How did you solved connections between chassis bottom and body? Please, picture from bottom! Thanks!
da_ashman
07-16-2013, 08:54 PM
Hey, thanks guys!
Heres a pic of the unfinished chassis, Ive removed the ugly bottom raditor thingys & am yet to clean up the paint job done by previous owner.
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/5B02B212-75C4-469B-93F9-17D0D2455673-5035-00000A629E3F1526.jpg
Its not perfect but will be adaquite
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/68B359AE-E0C8-40AC-AB97-A29B23332B1B-5035-00000A62A885C4AA.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/34F92119-2C1A-4146-8401-D8BDCB849370-5035-00000A62AE1C7E59.jpg
& The Decals Arrived!!!!
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/583C58F6-383E-4569-AE78-F57E06599300-5035-00000A62B8B3F3BD.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/62595605-5BE0-41B2-813C-D93899566B68-5035-00000A62B3892148.jpg
They came out WAY better than I was expecting.
If your in NZ (or anywhere else) & need some custom decals, check out www.electricdesigns.co.nz (http://www.electricdesigns.co.nz) very good service, really competitive pricing aswell.
Really looking forward to applying some of these decals & making the interior looked finished!
Hey, thanks guys!
indecentkikogt
07-18-2013, 12:00 AM
Lookin good, I've only seen one coupe and one roadster and they were both awesome lol keep up the good work
cjsbosox
07-18-2013, 10:23 PM
Not if I get it 1st! :naughty:
I'm off to start my SV fund by selling cookies outside of Walmart!
BTW good job Ashman
BTW good job Ashman
avd
07-19-2013, 08:54 PM
Sure does look great. Keep on posting.
da_ashman
09-30-2013, 07:46 PM
Hey Guys
Small update to start with. The White is on, the decals are on & 2K clearcoat is done!!!
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/86DFA260-F980-4C5A-8719-04F330CD6B80-443-000000D0410FECB4_zpsc0a35dae.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/B43A2369-89BA-40FA-85D2-0C590AB09438-443-000000D03A778397_zpsaabbce0b.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/25716C46-8CC8-4AD6-A2B8-5BE518638A87-443-000000D03DD24B16_zps85e3587d.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/EEA6FC3B-F5B3-40BF-AF2A-CED352E10567-971-0000026821521F85_zps30ef9f96.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/48416083-4046-490E-A097-DB15BD733BF5-971-000002682773443A_zps87343760.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/F84EE0E2-143C-4023-BD82-0623BB56447B-971-000002682DF3BD3F_zps41c82d16.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/AAA0D93E-8C3F-4E34-BD42-AEBA9FC164E1-971-000002682A5360BF_zps02f42a10.jpg
Its come out looking great, definetly my best clearcoat so far, dont think ill even need to polish it! Theres a few areas that require Semi Gloss Black but other than that the body is done, now just on to finishing the interior & chassis!! Speaking of interior, Ive got 1 shot of the decaled dashboard, should be able to get some better photos now with it being lighter at night.
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/523A3FA0-4D48-4349-AF92-D3F78BF3F3CB-1505-000002E3D1487C9E.jpg
Turned the flash on in photo above, the contrast isnt quite that high!
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/9313052C-0F4D-4DC2-A7F9-076DEBC6BA5C-443-000000D043F715AC_zps4e77a0ae.jpg
Thanks for looking, More soon I promise!
Ash
Ash
bejonek
10-01-2013, 04:21 AM
Good to see your progress! Good work.
andybmw7272
10-01-2013, 08:17 AM
Very cool! I love it.
Andy
Andy
da_ashman
10-08-2013, 07:51 PM
Thanks Guys!
So little update. Ive clearcoated the interior parts.
The special limited edition Versace Lambo has the full Carbon Fibre package on the Lambo options list & also Versace trimmed & embroidied leather interior. Ive seen a few variations on the net with differing coloured leather inserts, like door insert in white, centre consol in black, seats half white etc, very confusing considering Lambo reckon they only made 2 roadsters...
The patten required for the doors & dash was too small for me to cut & paint mask like the seats so a printed decal had to suffice but I think it represents the embroided 1:1 pretty well. I used Mirco - Satin for clearcoating all interior parts.
Enough words, picture time!!
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/5AE007C8-6CD2-4E59-B950-03FF55EF75E6-550-000001E70409018E_zps59ac26fb.jpg
Heres a pic with the flash on
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/E764DE3A-0297-4829-8A6E-D2748DC460F2-550-000001E70124707B_zps80122633.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/FA0438DD-8DD2-4F79-A11F-F8C949D9AA3B-550-000001E7062ACE6C_zps9cf24033.jpg
The Seats managed to get some dust in them whilst drying so need to fix that.
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/47E2A5CE-9896-42C5-9E0A-C048E6E3132F-550-000001E7097799A5_zpseebff556.jpg
With the interior finally out of the way I'm now gonna have to focus on the chassis & those epic brakes!
Ash
Ash
da_ashman
10-09-2013, 07:46 PM
I could start with taking some reference pics.http://www.derrckmde.com/12.jpg
Too true, heres some pics of the 1:1
This is the main image that I based my interior off of, its got full white seats, white centre & black door inserts. in my opinion this looked the best.
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/2008_Lamborghini_MurcilagoLP640RoadsterVersace2.jp g
& heres one with the white door cards
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/2009_lamborghini_murcielago_lp_640_roadster_versac e_3_1024x768.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/2009_lamborghini_murcielago_lp_640_roadster_versac e_7_1024x768.jpg
Heres the Coupe version, half white seats, black centre consol & black door inserts. & its on the roof, how awesome is that!!! Most expensive Header liner ever... possibly
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/2006_Lamborghini_MurcilagoLP640VersaceEdition3.jpg
Naturally being a partnership between Versace & Lamborghini there are accessories, this pic shows the set you recieved if you brough the car (I think) Shoes, driving gloves, Overnight bag & shoulder bag. There are quite a few other ones too, like larger overnight bags, keyring, watch, wallet, theres even a Versace trimed business card holder....
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/797174.jpg
This is BY FAR my favorite interior accessory!!!
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/442828.jpg
Cheers
Ash
Cheers
Ash
madonion48
01-06-2014, 02:50 AM
Very nice progress. I love how the door panels came out !
da_ashman
09-16-2014, 09:08 PM
Versace is back IN!!!
Trying to finally get this one over the line for forth cmoing national Show down here in NZ, only 10 days to go, so heres hoping!!!
anyway - Updates since last time
Body - Painted the satin black areas
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_7055.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_7056.jpg
The Interior - Been adding all the Photoetched parts, almost done, just seat belts to sort out & assemble
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_7052.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_7054.jpg
The Rear Lights - I was very dubious about this because I had to use the resin ones supplied with the Trans-kit. They are a little small for the area but there was nothing I could do, was worried about colour & clarity too with the very yellow clear resin. In the photo on top is the second pair I got, painted ones below. Overall reasonly happy with how clear they turned out. I 2K clearcoated them too
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_7057.jpg
The Engine Bay
Like my 40th Murc I wasnt happy with the engine, Its way to big & has no detail to it! I compared it with Aoshima's SV engine & its at least 6mm too long!!!! So i made some quick basic head detail & worked away on the resin intake (again too small!!) & adding all the PE pieces that go in here.
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_7051.jpg
The Brakes
This has been the biggest headache & most time consuming part of this build!! Each barke consists of 28 pieces + the plastic parts! there are 10 "bolts" that go into 10 "clips" That need to go into the 3 piece hub & 5 piece rotor!!! Increbly detailed!!!
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_6845.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_6844.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_6891.jpg
& the Final score sports fans! I won!!! - best bit of advice I had was to do it all on a piece of A4 paper, tiny metal parts are much easier to find on white than Green boards & carpet!!!
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_6982.jpg
Thats about it for now, will hopefully update this again very soon!!
Cheers, Ash
The Engine Bay
The Brakes
Cheers, Ash
jzx100
09-18-2014, 11:24 AM
The brake rotors look amazing.
Nice work with the car, all the carbon fiber, the interior and everything
:smile:
:smile:
circuitR
09-22-2014, 05:37 AM
Looking awesome Ash! Those brakes are a lot of work and they look amazing
da_ashman
10-06-2014, 08:05 PM
Shes Done - Completed Pics Here http://www.automotiveforums.com/vbulletin/showthread.php?p=7145547#post7145547
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_7163.jpg
Some final pics
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_7078.jpg
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_7079.jpg
Made it to the Show
Even made some Handbags - the Wife always said she wanted a Versace Bag...
http://i154.photobucket.com/albums/s258/da_ashman/Versace%20LP640%20Roadster/IMG_7087.jpg
Thanks for watching & all the posts too
Ash
Some final pics
Made it to the Show
Ash
