2008 TB radiator drain
tgwright
06-25-2011, 02:08 PM
It's time to drain the radiator on my '08. I saw the thread indicating the drain on the '03 is on the left (driver's) side on the bottom, but I can't seem to find it on my '08. Anyone know for sure?
maxwedge
06-25-2011, 06:48 PM
Should be the same spot you really need to get under there to find it, has a black plastic flange on it.
tgwright
06-25-2011, 08:56 PM
I looked all around under there today, but I'll look again. Exactly where is it in relation to the return hose? Could it be hidden under a plastic shroud? I've never had a problem finding the drain on any of my other cars.
maxwedge
06-26-2011, 08:41 AM
You really have to crawl under to see, as it sits just above the lower radiator support.
kevinande
06-26-2011, 08:49 AM
If you can not find it, you could always just remove the lower hose. It's much faster that way too.:iceslolan
tgwright
06-27-2011, 07:15 AM
Yeah, that's what I ended up doing. Even when the hose is pulled off only partially it's very difficult to control the flow. Makes a mess of the garage floor. On jackstands I used a big worklight and looked everywhere but just couldn't find a drain. I'm glad I only do this every three years.
