88 thunderbird turbo coupe starter relay
gereeve
06-07-2011, 09:47 PM
i have a 1988 ford thunderbird turbo coupe 2.3 L. i just changed the starter, alternator, (they are testing good) and starter relay. i have the positive cable going to the b terminal on relay, starter going to m terminal, ignition switch lead to the s terminal. there are two other wires that i thought went to the b terminal but when you try to jump the car it turn over even with out the key in.
97Bird
06-08-2011, 05:57 PM
Welcome to the forum gereeve. Are you trying to jump start the car because the battery in the car is dead? Where are you connecting the jumper cables? Do you have a multi-meter to test the electrical system? Remove the ignition switch lead from the relay and connect the battery again. If the engine turns over then you have a bad relay.
