Need New Shocks For my 89 F250
chamblizi
05-15-2011, 12:06 AM
Hi names Phil i need new front shocks for my 1989 Ford F250 i want to buy some Gabriel Load carriers since i have a heavy 351 big block engine its a 5.8L and my old shocks are about shot they spew oil and this might be my wandering problem
anyone here using Load Carriers? and how would they work cause my pickup sits to low in the front its supposedly:jerking: caused by the bad shocks
inafogg
05-15-2011, 12:19 PM
the shocks mentioned are a good brand,but dont be exspecting them
to raise the truck hieght.look elsewhere for that ie springs/
chamblizi
05-15-2011, 12:41 PM
im not trying to raise it im trying to level it
inafogg
05-15-2011, 02:27 PM
ok if the rear ride hieght is ok, but the front is lower than specs you'll
still need to bring front up to specs.how much is it off??is l/f/ r/f sitting
at the same level??how much is the hieght off??
i no your not looking to raise the ride but to bring it into specs.
chamblizi
05-15-2011, 02:29 PM
just by a few inches or so its the shocks for sure though cause the lack of pressure caused by shocks creating more lean on my coil springs
inafogg
05-15-2011, 03:00 PM
well you can see how much the new shocks help,but if its not enough
you can install some spacers in the coil springs.
Good luck
chamblizi
05-15-2011, 03:02 PM
Good luck
kk i was intending to add spacers though after i get the wandering problem under control check my profile to see what im talking about theres a photo of my pickup on here
chamblizi
05-16-2011, 11:18 PM
the front is sitting = low check my page you can see what i mean in the profile picture.... i also have front susppension problems which is causing wandering some of my fittings need greasing and replacing like tie down rod ends and shocks they all are causing wandering problems
