96 chev ac does not blow hard
philrmech
05-05-2011, 07:52 AM
I have a 96 chev pu and the air does not come out of ac vents.The air is blowing and it comes our on def and in the floor in that mode but not out of ac vents. help thanks philrmech
brcidd
05-05-2011, 08:08 AM
Check your mode door actuator, behind driver's side knee bolster on left side of HVAC housing-- you must lay on your back and use a flashilght to see it.
See if it is moving, not binding, if all armas are connected, not flopping around.
Lat on I did had a plastic Walmart bag sucked up into recirc door- but his complaint was blows good until you hit recirc button.
autotech234
06-07-2011, 05:39 PM
very common problem you bend door is control by vacuum and when it looses vacuume it defalts to defrost. Under the hood on the passager side there will be a small plasic vac line coming throw fire wall going to the top of the engine manifold, follow that vac line and check for leaks if it is leaking repair them and that will fix your problem
