Rear end Front seal Leaking/ I think water Is getting in
S10SNODOG
04-17-2011, 06:43 AM
2003 Chevy s 10 4 wheel drive V 6 vortec motor I believe the Rear end is leaking From the fronte Yoke seal how big a job to fix it I think you got that way from the driveshaft having e a slight vibration PLEASE HELP THANK YOU
S10SNODOG
04-18-2011, 02:20 PM
When I pulled the drain plug out A muddy oily reddish color contaminated oil came out it does have a small week
inafogg
04-18-2011, 03:03 PM
not a bad job,mark the driveshaft to yoke & yoke to diff so they go back
in the same position.
remove drive shaft,remove mounting nut,remove yoke by hitting w/brass hammer.
you can tap the edge of seal to remove it.
NOTE:check torque on mounting nut(yoke) before removal,so that the proper
preload pressure is applied on reinstallation
they do show 2 special tools,1 for holding rear from turning,1 for seal installation.not sure if they are really needed
Good luck
S10SNODOG
04-19-2011, 05:43 PM
What size is the ring gear is it 8.5 or 8.625. And if it 7.5 it's a completely different seal????? CORRECT
inafogg
04-19-2011, 09:30 PM
parts store will have that info.what i see is the 7.5 & 8 inch are the same
part #.for a 03 blazer 4.3L 4 wh drive
Good luck
S10SNODOG
04-20-2011, 01:58 PM
The big nut thats Behind the knuckle Is that pressed on at all 8 threads regular or Reverse thread
