oil in spark plug hole
accordztech
05-28-2003, 01:05 AM
ok last time when i worked on my waterpump and timming belt i noticed oil inside spark plug 2 (from drivers side) had oil in it. i said o well and bought all new gaskets for everything. recently i looked in there and with teh spark plug in place their was still oil in there. i cleaned that out before as well. why now, 3 months later, ihave oil in there again? anything else causing it?
thanks
thanks
BullShifter
05-28-2003, 02:19 AM
did you replace the rubber seals on the bottom side of the valve cover? There is 1 for each plug
accordztech
05-28-2003, 02:21 AM
yeup all 4
BullShifter
05-28-2003, 02:42 AM
valve cover tightened properly?
are the spark plug tubes ok?
accordztech
05-28-2003, 03:47 AM
yea valve cover is tight with new bushings. spark plugs wires are great. plug is tight. weird huh.
BullShifter
05-28-2003, 11:43 PM
How about this, the spark plug tubes are made in 2 pieces with a seal in the middle. Thats the only thing left, that would let oil in your tubes. To replace theses seals you must remove the rocker assembly.
lorunner
05-29-2003, 08:41 PM
try Honda o-rings the aftermarket ones are usually shit and don't hold up
accordztech
05-30-2003, 06:14 PM
for parts like this i only use genuine honda oem.
jacksi ill reply to u in a little sorrie. but ill PM u tonight as well. thanks bro.
i havent had the chance to take off the head yet. ill do it today and see what i can find...possible locaitons of leaks and such.
accordztech
06-21-2003, 03:24 AM
well last week i cleaned out oil out of there again, and today i was going to take it off and i see there is no fluid in my hole. so i said forget it. next time it happends im putting some rtv sealent on there, the haynes manual says so, i just never have.
so i guess the problem is fine for now. next time, next time.
