Transmission pan gasket
FRANKENCAMRY
03-05-2011, 05:27 PM
Replaced tranny fluid & filter a couple of years ago and have had a slow leak in the silicone gasket ever since. Getting ready to do it again and am considering using a rubberized pan gasket (from RockAuto) this time. Anyone had luck with these?
MagicRat
03-05-2011, 05:33 PM
Is the pan bent anywhere?
These pans often get slightly distorted around the bolt holes from overtightening.
You can place the edge of the pan on a wood block and gently hammer down the high spots around the bolt holes with a ball-peen hammer.
All the metal surfaces where the gasket goes must be completely free of grease and oil and totally dry. I find using a spray can of brake cleaner a great way to quickly degrease the surfaces.
Finally, don't over-tighten the pan bolts. They don't need much torque.
rhandwor
03-05-2011, 06:02 PM
Use a small screwdriver and remove all silicon out of the bolt holes. This makes the bolts very easy to break even with a 1/4 drive socket. The rubberized gasket will work fine. Use some grease after cleaning to hold it in place.
FRANKENCAMRY
03-05-2011, 06:39 PM
Several of the hole threads stripped the first time I had the pan off. I knew that they required very light torque and I definitely didn't crank them down hard so I'm not really sure why they stripped - it almost seemed like they must have stripped on the way out. Anyway... now I probably need to either use a helicoil or tap the bad holes. Before I do either I'm going to try a longer bolt - maybe the holes are deep enough that longer bolts would have something to grab.
Scrapper
03-05-2011, 06:42 PM
i second that on the bolts and agree to a rubber gasket not cork.
FRANKENCAMRY
03-23-2011, 06:31 AM
Update: The transmission pan bolt holes are a few mm deeper than the original bolts. Cleaned up the bad threads with a tap (8mm x 1.25) and used longer bolts. All good.
Alphabravo
03-23-2011, 08:53 AM
Thanks for the update and I'm glad it workd out well for you.
