91 lumina stalled / wont start
kruz_31
01-24-2011, 04:54 AM
i was driving down the road and the car just died like i shut it off , tried to restart and it does nothing lights and everything work just wont role over any ideas thanks for the help
maxwedge
01-24-2011, 01:53 PM
No starter engagement at all? Battery cables tight?
slingslingbinks
01-26-2011, 08:22 PM
Make sure that the check engine light is on with the key in the on position. Also check the fuseable links by the starter.
maxwedge
01-27-2011, 02:36 PM
This car does not have fusible links, it uses large master fuses in the under hood distr. box.
Scrapper
01-27-2011, 03:06 PM
sounds like to me if no click when trieing to start it if lights and all works? or you might try to clean cables and make sure there tight like there telling you.
good luck............
maxwedge
01-29-2011, 12:02 PM
This car does not have fusible links, it uses large master fuses in the under hood distr. box. I may be wrong here, 91 could still have them.
