crank bolt
crxlvr
05-24-2003, 10:05 PM
ive tried torque wrenchs, hand wrenches, sockets, and impact guns and nothing will budge this mutha, all i did was loosen the damn bolts on the other side, i need to get this thing out, help me.
b16 btw.
Venger10
05-24-2003, 11:17 PM
Soak the **** out of it with WD40 or some other "magic solution" for about a day or so. Tap it LIGHTLY with a hammer occasionally , the vibration helps the liquid soak into the threads......
Impact gun should be easy after that.
Is this the bolt in the front (pulley end) ???
crxlvr
05-25-2003, 06:24 PM
yea its the pulley bolt, and i gotta get it off so i can get my piston rings seated, ill try some PB blaster, that shit is amazing.
jeef
05-25-2003, 11:42 PM
yeah def. soak that mother in Pb (that stuff is the shit) and hit it with the biggest impact gun you can get your hands on
91civichatch2571
05-25-2003, 11:49 PM
my impact gun is a lil weak so I always use the good old breaker bar. Put the bolts back in the flywheel side and put a piece of metal through them. Kinda like this if you get it % so that the bar hits the floor and doesnt allow the crank to turm anymore. Then put the breaker bar on the pulley bolt and put all your weight on it. Sorry if you dont understand that but anyways, good luck...
johnb16a2
05-27-2003, 09:17 AM
All good advise, got mine off with lots of penetrating oil, tapping on it, a big impact wrench (rent one if you have to) and no heat! (the bolt might snap). Good Luck.:)
sastanley
05-27-2003, 09:43 AM
lol dude..nice 'diagram' - i understand that concept, but it is a great diagram for those new to the world of lever-bars etc... :cool:
crxlvr
05-27-2003, 10:22 AM
i get the diagram completly beautiful work there. since i dont have easy access to an impact gun, hopefully my 24" breaker bar and some PB will do the trick.
