Cause of 1994 s10 blazer losing spark
Mccaden2011
01-14-2011, 09:40 PM
I have a 94 chevy s10 blazer 4dr 4x4 with the 4.3L TBI vin w. It has suddenly lost spark. What would cause it to do so? We have replaced the coil and spark plugs but still appear to have no spark. What should we check or replace next please let me know asap thank you
MT-2500
01-15-2011, 09:41 AM
Where are you checking for lose of spark?
At plugs or right out of coil?
Is it the old style dist or new flat top dist?
Is dist shaft and rotor turning when cranking engine?
Any codes?
blazes9395
01-15-2011, 05:19 PM
HAve you checked the ignition control module, under the cap? They can be tested, before changing them.
albertpaul68
01-23-2011, 11:24 PM
Probably a weak fuel pump. Before you start the car turn off the fan, radio and anything else that will make noise. Close the door and roll the window down ( this keeps the door buzzer quiet) and turn the key to "on" being careful not to engage the starter and listen. You should hear a low growling sound coming from under the car in the gas tank. it will only make the noise for a few seconds so listen closely. If you do hear it the fuel pump is working and you should probably change the fuel filter and make sure the fuel lines are not cramped. Also ( in the believe it or not category) make sure the fuel cap is on and you hear three clicks when you tighten it. If you don't the fuel tank won't pressurize properly. Good luck.
Jerry80871852
01-24-2011, 07:46 PM
Why is it you think a weak fuel pump will have an effect so that he has no spark?
FishFind
04-22-2011, 08:19 PM
haha
linn2002
05-23-2011, 06:15 AM
if it has no distributor, check ignition control module under coil packs.
