95' Lesabre off idle missfire - Unable to read code
Cornchip
01-04-2011, 08:14 PM
Did some reading on the forums tonight about 'fishbite'. I like the analogy as it fit's so well the way it feels. My Lesabre is a 95 with a Series 1 3800. I'd say it's generally well taken care of with new NGK direct fit wires and delco plugs done a year ago.
With the check engine 'on' tonight for the first time ever, is there a way to verify that it has coded because of a missfire?. As you probably guessed already, I don't have a scan tool for this OBD1? style ECM. Do I even need one, can the code be reset by disconnecting the battery?
Clint.
danielsatur
01-04-2011, 08:17 PM
Stop at the local Auto parts store, they can pull code for free!
HotZ28
01-04-2011, 11:17 PM
Stop at the local Auto parts store, they can pull code for free!"the local Auto parts store" will not have a scanner capable of reading OBD1.5 which the '95 has; it takes a special scanner with OBD1 & OBD11 communication. :eek7: Do a search on this site for recommendations on what is compatible.
Jrs3800
01-05-2011, 05:04 PM
Yes he need a tool that will read the funky 94-95 GM OBD1... 99% of all parts stores can only read OBD2...
This car has the OBD2 connector but runs on the OBD1 Protocol, But it has to be read with a tool that is capable of reading this car as it uses 5 didget Pxxxx codes..
