Radiator
heartattackjames
12-15-2010, 03:03 PM
Hello all, I'm a newbie here so bear with me. I have a 1995 Silverado pick-up and I'm having a bit of a problem. My radiator leaks around the upper oil cooling line. I disconnected the oil line and removed the nut that holds the fitting in the radiator. My question is how do I get the fitting out to change the o-ring on it. All info would be greatly apppreciated. Thank you, James
MT-2500
12-15-2010, 06:31 PM
Welcome to AF on your first post.
What nut did you disconnect plastic or metal?
The one next to rad?
or a nut on end of cooler line?
Can you post a picture of it?
Is the oil coller line the push in type they call quick connect that takes a while to unplug unless you have the tool to do it?
heartattackjames
12-19-2010, 12:07 PM
Sorry for not responding earlier, the nut is the one that holds the oil cooler tight to the radiator. Apparently the o-ring had given out and I was trying to put new one into radiator over the fitting, to no avail, so as of now the o-ring is outside of radiator being held in place by tightened nut, I was told that it would be a waste of time and money to try to get it into radiator and that a new radiator would be needed. So I guess I'll wait til after first of the year to get it. Thanks for your reply, James
MT-2500
12-19-2010, 04:23 PM
No problem on late reply.
Late is a lot better then never.
Yes you are probably fighting a lost cause.
But sometimes a band aid fix can help.
A good flat rubber and a good steel washer to fit the cooler pipe and some good permetex import gray silicone may help hold on it.
Good Luck
Good Luck
