Axles for swap B16A2
emil13si
05-22-2003, 11:28 PM
So now I came this far that I have almost all performance parts for my engine and next month we'll start rebuilidng it and the engine will have mad spec at least for a while I got some ITR parts for it (the whole upper part) so the has kit is in it's way to me so now all I have to do is find the right axles for my swap in here in Europe so which ones will be good, any advice???
I was thinking about 98'up ITR axles will those fit and be good for my swap????
THNX for your help
So till now I got this parts:
*Already bought:
-HASport mount kit
-HASport shift linkage
-HASport wire harness
-DC cheramic 4-1 header (race)
-Race clutch
-mugen metal head gasket
-ITR camshafts
-ITR cam gears
-ITR valve springs
-ITR valves
-ITR oil pan + oil pump
-valve cover from 1.8 VTEC civic
(I wanned the ITR one but my friend was quicker :( and he bought it befor me,
but I'm happy with the 1.8 one too ;) )
* want (and I hope I'll get that soon)
-ITR whole dash
-ITR back seats
:flash:
jNYCe5
05-23-2003, 08:21 AM
are you going to use the hydro tranny or stay with a cable one? as for axles, you should use the ones that come with the motor.
good luck man
Setanta
05-23-2003, 08:39 AM
I'm pretty sure Emil said in an earlier post that he was going hydro.
Cheers
mellowboy
05-23-2003, 10:06 AM
IF your goin Hydro then you should be able to fit the 94 and up integra or any civics that came with b16s.
emil13si
05-24-2003, 08:38 PM
YUP I'm going for hydro and if you're correct on that that any axles from all B series civic will be fine I won't have problems with finding that, at first I was thinking about ITR ones but we'll try if the one from civic with B series if those will be alright I'll take those if not we'll try the ITR ones if those will mach my swap...
THNX again
