2000 S10 4.3L Rough Idle PO304
paulson
10-09-2010, 12:32 PM
I'm trying to figure out just what the heck is wrong with this truck...
It's a 4.3L with 169K on it. I've changed out the following (in hopes of getting it to stop idling so poorly and throwing the code)
- Replacement spider (fuel injectors/fuel pressure regulator... weren't new but vehicle is doing the same thing so I imagine it's not the injectors)
- Replacement spark plugs (delco), spark plug wires, new distributor, cap, and rotor.
- Replacement oxygen sensors
- Replacement TPS, IAC, MAP, MAF... (I have a perfectly good working 96 blazer with the same engine and am able to swap parts for testing purposes.)
The fuel pump is having issues (sending unit doesn't work and I have rough starts... in general I believe it's an issue but I don't think it would cause the engine to idle rough or cause cylinder 4 to misfire)
The catalytic converter is shot... needs a replacement but I do not want to replace it until I fix the other issue (don't want to ruin a new cat... unless it's clogged and could be causing the problem?)
I'm going to be putting in a new fuel pump however if that does not resolve the issue I might take it to the dealer...
Any ideas? I want to put the new MFI injectors into it however I'd rather not spend that kind of money on the upgrade kit if it didn't resolve the problem.
Thanks!
Thanks!
j cAT
10-11-2010, 10:56 AM
the #4 cylinder missfires so I would check the compression and see how the cylinders compare.
check plug color for determining how #4 is working.
coolant/excessive fuel/vacuum leak.
paulson
10-13-2010, 02:02 PM
I forgot to mention that I had just replaced the water pump/radiator and whatnot so that's clear.
I took it to the dealership and unfortunately compression was low on #4 (they also said fuel pressure was low as well which I figured as the fuel pump isn't working as it should be.)
If I get fuel pressure to where it should be (will be changing out the fuel pump) do you think it'd help at all?
The dealer wanted around $1700 to tear the engine apart and fix it, $3600 for a used engine with 120K on it or $5500 for a reman engine.
I've found a replacement engine with 82K on it for $550 however I don't know how much it'd be to have a decent mechanic install it (I'd do so myself but I don't have a lift or a way to hoist the engine out.
Thanks
Thanks
j cAT
10-13-2010, 08:49 PM
since your not working on vehicles when they get this old just buy a new or newer vehicle.
when the engine or transmission fails and your looking at more than a thousand to repair a vehicle worth a couple of thousand is not wise.
you may just need a new head or head gasket. possibly a bad valve or just a weak spring.
measure the fuel pressure . If it starts good pressure should be good. bad idle missfires are from the #4 low compression.
