Starting problems
iceman2
10-04-2010, 09:01 AM
1997 TP, 3.4L, 175,000 miles. Will initially start as normal - then immediately dies. Stays running if I lay on the gas a little bit, can smell gasoline during start-up and while engine is running.
Blue Bowtie
10-05-2010, 08:01 PM
Test the fuel pressure with the engine off. Once the pump stops running the pressure should hold for several minutes. If the pressure drops off rapidly it can be a sign of a leaking injector or pressure regulator. Either can cause a flooding condition which would be helped somewhat by holding the throttle open to admit extra air.
