94 mustang gt won't run
swannie958
10-01-2010, 06:37 PM
having problems--no fuel getting to the motor. have tried replacing the fuel pumps 3 times, no luck. just replaced the fuel pump relay (the one beside the coolant reservoir) still no fuel getting thru. any tips on testing whether the fuel pump is good or bad??
old_master
10-01-2010, 07:58 PM
Can you hear the fuel pump run? If not, did you check the inertia switch, fuel pump relay and the PCM power up relay?
Kybar
10-03-2010, 02:19 PM
turn the key over and listen for the wind of the fuel pump, Also have you changed your fuel filter? a clogged filter can stop the flow and its often overlooked
swannie958
04-13-2011, 11:25 PM
thanks old master and kybar for the advice. replaced the fuel pump relay, and it cranked right up. thank you so much. it really helped. you guys are great
thanks again,
swannie958
