Datsun Fairlady 432ZG ???
crazy-jazz894
09-09-2010, 03:13 AM
Hi every one , This's what on my workbench now. The Fujimi Fairlady 240ZG. I started to work on this car for a while.
At the beginning ,I think that I'll make it as the full open & details model. But due to many reason I change my mind and opened just the engine hood.
Starting with opening the hood.
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P4300763_resize.jpg
Removed the logo that come with the kit ,will be replace with metal logo later.
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P4300764_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P5110804_resize.jpg
fire wall need to be fill up with some plastic sheet.
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P5020769_resize.jpg
After fire walled.
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P5030782_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P5030780_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P5030779_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P5030778_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P5040784_resize.jpg
After fire walled.
crazy-jazz894
09-09-2010, 03:17 AM
Cut the body for the radiator air duct channel.
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6060852_resize.jpg
Fitting test.
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6060845_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6060844_resize.jpg
I don't know what does it call ,but it can be open too.
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P5110801_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P5110802_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6060856_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6060854_resize.jpg
Fitting test.
KevHw
09-09-2010, 08:37 AM
Nice progress so far. Engine bay area is already looking much better after you closed it up. Looking forward to seeing how you progress on this one.
crazy-jazz894
09-09-2010, 11:55 AM
Down to suspension I cut the lower arm to lowering it.
Cut it & drill the 1mm. hole. I use the Tamiya 1mm. plastic beam as a suspension pin.
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6070864_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6070863_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6070865_resize.jpg
Before
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6070867_resize.jpg
After
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6070862_resize.jpg
Compare with the other side you will see that it is much lowering.
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6070861_resize.jpg
Before
After
crazy-jazz894
09-10-2010, 01:29 AM
The rear suspension arm are also cutted for lowering it too.
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6070868_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6070869_resize.jpg
Then cut the shock up & spring both front & rear. As you can see in the pictures. The standard one is on the left side ,the cutted one is on the right side.
Front Shock
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6070879_resize.jpg
Rear Shock
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6080884_resize.jpg
When it fitted on the car it will be like this
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6070877_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6070872_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6080888_resize.jpg
Front Shock
Rear Shock
crazy-jazz894
09-10-2010, 01:45 AM
Fitting test with the wheels.
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6080891_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6080894_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6080893_resize.jpg
Go on with painting the suspensions. F&R brake are replace
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6230903_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6230908_resize.jpg
http://i194.photobucket.com/albums/z43/bozz894/Fairlady%20240ZG/P6230906_resize.jpg
rollin80s
09-10-2010, 04:36 PM
nice nice nice, love where this is going.:iceslolan
soooo, what's up with the resin work meisters??:naughty:
