Racing43 wheels on a Tamiya kit.
Marco_Wrc
05-16-2003, 11:07 AM
Ok, I've read the howto on converting female wheels to male, but...
I've got white metal wheels from Racing43 here, also female.
I don't have the right tools (dremel) to do the conversion, and I'm not buying one.
But I was thinking, can't I make a hole in the brakedisc so it slides over the rod of the wheel?
So, making a hole the size of the red circle.
http://files.automotiveforums.com/uploads/379168brakedisc.jpg
And then slide it over the rod of the wheel.
http://files.automotiveforums.com/uploads/949391racing43.jpg
Now, I'm not sure at all whether this is going to work or not. Has anyone done this before?
nervestrikes
05-16-2003, 11:27 AM
I think you got a workable idea there, but how are you going to cut the hole with out a dremel or a drill? Either way I say try it!:D
freakray
05-16-2003, 11:39 AM
Wonder what you're building ;) :rolleyes:
You could try to get hold of some Fujimi brakes which will theoretically save you having to modify those, if not though, I think your idea will work as long as you have something to hold the wheel.
It looks like those Racing43 wheels were made for straight rod axles?
Marco_Wrc
05-16-2003, 12:23 PM
It's for the 2002 San Remo Rally Focus of Markko Märtin. I started working on it this week. A lot modifications have to be done. The rollcage is almost done, and today I wanted to work on the wheels.
In fact, I just finished the first one (took me a quarter of an hour to file a nice round hole in the brakedisc). Will post a picture in a moment.
I think these wheels are made for straight axles indeed. Racing43 makes white metal kits without working steering, so maybe that's why they're made like this.
freakray
05-16-2003, 12:28 PM
That's exactly what I thought you were up to :D
The roll cage mod is one of the easiest ones if you ask me ;)
Marco_Wrc
05-16-2003, 12:47 PM
I'm too predictable :) I had this one on my mind for some time.
Here's the result. Not very clear, but believe me it's there.
http://files.automotiveforums.com/uploads/730542QC4200305161926310.jpg
Only problem is, when you rotate the wheel, the brakedisc also tuns. I found a rather clever solution for it: DON'T ROTATE THE WHEEL. :D
Getting the rollcage right isn't that hard IF you have good interior shots. They're scarce, but I found some (though I'd love to have more of them *hint *hint).
freakray
05-16-2003, 01:02 PM
You could always make a wire pin from the brake to the bub so that the brake caliper doesn't rotate.
Maybe you could share the photos you have of the roll cage then, I have photos of the 2001 roll cage but not the 2002.
Do you have any plans for the headlights?
flyonthewall
05-16-2003, 01:10 PM
I did a similar thing with my S2000
http://www.automotiveforums.com/vbulletin/showthread.php?postid=632295#post632295
008
05-16-2003, 02:09 PM
Most of my models are like that. Rotating wheels are just disasters waiting to happen. Been there, done that. I glue all my wheels solid now.
Marco_Wrc
05-16-2003, 03:11 PM
Sure, I've uploaded them here (http://members.chello.nl/m.kleijer/ford/).
I have some questions left, and one of them is:
- Where does the spare wheel go?
I've thought about the headlights. It might be a good opportunity for me to learn how to use putty.
http://www.automotiveforums.com/vbu...2295#post632295
That's the thread I was looking for. I remembered you did something similar, though it is different from what I did today.
freakray
05-16-2003, 03:21 PM
If you look in this photo, http://members.chello.nl/m.kleijer/ford/200209261030_SRMarkkoincar.jpg you can see the seatbelt strap going to the back cross brace which also acts as a support point for the basket carrying the spare wheel.
From the photos I have seen of the rear interior of the 2002 car it utilises the same spare carrier as the 2001 car.
I have some plans for the headlights :devil:
If you want, you can PM me and we can 'discuss' ideas, I am away this weekend but will be home early Sunday so will be able to get back to you then.
Ray
Marco_Wrc
05-16-2003, 03:48 PM
I'm not so sure about that. In some 2002 Focus cars the spare tyre is strapped beneath that bar. I think I'll contact fordrallyesport about this, or do you have a picture of it?
I'll pm you tomorrow (also about the website), have a good weekend.
bigfrit
05-16-2003, 04:24 PM
Funny pic of marco scratching his crotch!:p
Guido
05-16-2003, 06:00 PM
Thanks guys for bringing this up. I have also a set of Racing43 wheels, but was still in doubt of how to use them. Now I got some inspiration! Thanks Chris for the link ;)
