95 s-10 ecm ign fuse keeps blowing, HELP!!!
jjgierke5
08-21-2010, 02:24 PM
I have a 95 s-10 that the ecm ign fuse keeps blowing. I replaced the fuse and it will start for a few minutes and then the fuse blows and it wont start. anyone please help im lost now.
MT-2500
08-21-2010, 10:20 PM
Several things on that fuse.
VCM and IGN and injectors and crank and sensors and coil and driver module.
Is it a 4.3 with TBI injection?
If so check for pinched injector wire and next thing to check for is a shorted injector or injector wiring.
Let us know what you find there.
viggy58
08-22-2010, 10:49 PM
something similar happened to me.
apparently, i hit a bump hard enough to pinch a wire coming out of the bottom of the fuse/relay center. as soon as i started looking through the harnesses, i found it, fixed it, and go more problems.
MT-2500
08-23-2010, 08:12 AM
Good find on your problem.
Thanks for posting back the find and fix.
If any more problems post back on them.
Good Luck
