2004 Grand Prix P0107
barntime
08-12-2010, 06:57 PM
I have P0107 on non-supercharged 3800. 5 volts reference signal and 51mv
output from MAP sensor. There is oil dripping from sensor. Is this normal?
PCV is new AC Delco 692.
shorod
08-12-2010, 09:54 PM
Uh, no, oil dripping from the sensor is not normal. Are you sure you are looking at the MAP sensor?
-Rod
-Rod
barntime
08-13-2010, 09:05 AM
Yes. On the 3800, the MAP sensor is located above the PCV valve.
shorod
08-13-2010, 07:15 PM
The suggested possible causes for a P0107 code are:
Open in the circuit or short to ground
VREF circuit open or short to ground
Damaged BARO/MAP sensor
Damaged PCM
-Rod
Damaged PCM
-Rod
RahX
08-13-2010, 07:52 PM
51mV while the engine is off? How does the engine run? What is the reading with the engine running?
barntime
08-14-2010, 02:06 PM
The sensor registers 51mv at all times. I realize that value needs
to change as rpm changes. What would cause oil to pass through PCV valve
to get to MAP sensor?
Joe
Joe
