2004 eclipse gts cylinder 3 misfire
nikesb1221
08-10-2010, 02:04 PM
hey my cel keeps coming on in my eclipse for cylinder 3 misfire ive had spark plugs plug wires and distributor cap replaced does anyone know what else it could be??
RahX
08-13-2010, 08:41 PM
I would check compression and see if the injector is firing. How did the plug look?
nikesb1221
08-15-2010, 11:46 AM
i had my mechanic look at the plugs again said they looked good. my cel goes on and off usually miss fires in higher rpms
RahX
08-15-2010, 12:31 PM
Still need to get some base engine numbers. Vacuum at idle, compression, timing belt marks, fuel pressure.
MiseryMissy
03-19-2011, 03:23 PM
There is actually a PCM update for this. I had it in my 03 early on. The Mistu Dealer that I worked with performed the TSB and I was ok after that.
And actually just to get a little more clarification, is this an idle misfire or high speed misfire?
808drifter
03-20-2011, 12:40 AM
Quit bumping dead threads.
