Novitec Rosso Ferrari 599
Pages : [1] 2 3
Entau
07-22-2010, 07:21 AM
Started this after i get many inspiration from Ramon's Hamann 599, not going to be exactly, just few elements & wheels from Novitec Rosso 599 :icon16:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/novitec-rosso-599-gtb-2.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/novitec-rosso-599-gtb-3.jpg
Detail & closer look at the HD's Novitec Rosso wheel
http://www.automotiveforums.com/vbulletin/showthread.php?t=1018012
Many imperfection on the wheel, sanded, filled, sanded, filled ...boring process...:shakehead
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5702.jpg
Here's the result, still require some touch up
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5762.jpg
Novitec Rosso's rear wheel was 21", mine was 20", so it looks a bit small at the rear
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5760.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5758.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5757.jpg
On the rear bumper, there should be 4 round reverse sensor
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5763.jpg
so i drill holes using 1.2mm drill bit and insert some kotobukiya's parts 1mm rivet
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5764.jpg
The Front Splitter
First i trace the 599 front bumper's shape using masking tape, then i transfer it to a piece of plastic card and design the shape of the splitter.
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5765.jpg
After that i trace the shape again using another piece of masking tape and make few template on 0.5mm plastic card.
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5766.jpg
I draw line where the bend will be and by holding it using a plyer, i heat it up using cigarette's smoke's, after few seconds i bend it. I try lighter before but the flame is to much and warp the thin plastic (by bending it without heat will weaken the plastic, and please non-smoker don't buy a pack of cigarette because of this :rofl: )
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5767.jpg
here's a rough shape (actually this is the 5th attempt)
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5769.jpg
after i confirm the position, i drill holes from bottom and insert some plastic rod
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5771.jpg
After some sanding, i glue some 0.5mm bended plastic card at the side
TOP VIEW:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5772.jpg
BOTTOM VIEW:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5773.jpg
Also my first attempt on the rear spoiler
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5774.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5775.jpg
not exactly what i want, but i'll leave it for now
Here's the overal look with the front splitter & 'rough' rear spoiler
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5779.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5783.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5784.jpg
Close up on the sanded & shaped front splitter
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5781.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5782.jpg
Interior will be like below:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/Ferrari-599_GTB_Fiorano_HGTE_2010_1600x1200_wallpaper_2a.j pg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/Ferrari-599_GTB_Fiorano_HGTE_2010_1600x1200_wallpaper_2c.j pg
it will be combination of very dark grey, almost black in semigloss + carbon fiber or gloss steel + flat black + black flocking
i havent decided whether to use carbon fiber like below which is a 1/48 scale very small pattern, almost black if not look up very close
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5787.jpg
or gloss mr color steel no28 (new one, the old mr color steel look brownish) which is much easier
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5793.jpg
(top is clear gloss, bottom is pure mr color no28)
cut out the aircond vent, it will be replace with pe later, also re-scribe the shallow panel line
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5828.jpg
remove the buttons with 0.8mm drill bits
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5788.jpg
use some 0.7mm round hex from top studio, i use the bottom which is flat to replicate the buttons
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5789.jpg
not perfect but at least it look more like a button instead of a nipple :rofl:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5790.jpg
original door
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5792.jpg
cut out area where it suppose to be holes, initially i just cut where the holes should be, but the confined space make it extremely hard to sand, no choice but to remove everything
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5829.jpg
then just add some 0.3mm pla-plate
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5830.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5831.jpg
Ferrari TR
07-22-2010, 01:25 PM
Great work. I hate to say there's too much detail in the interior. Don't get me wrong i like what you've done, but things like the door pockets are at best going to be hard to see in a closed car. That paint seems a great solution to the very hard to decal interior cf parts though. Could you post a picture of the bottle, as i'm not sure what the differences are between the old and new?
73superduty
07-22-2010, 02:13 PM
Fantastic work! I love that car since seeing it in my Forza issue.
As Ferrari TR mentioned, how about a glimpse of Mr. Color Steel. Bottle/Spray? Did you airbrush it?
Anyway, great work on an awesome car!
Chris
jano11
07-22-2010, 02:28 PM
Excellent work on the wheels! :thumbsup:
cjsbosox
07-22-2010, 03:06 PM
Entau great work so far. How thick is the styrene you used on the diffuser? Also, consider a taller tire to fill the wheel space in the rear.
Will follow this one :)
Tompidom
07-22-2010, 03:54 PM
I like the look of the front splitter with the wheels. And about the CF i would say dont paint it and also i would not use the 1:48 scale carbon. I would use some Scale motorsports 1:24 CF it is the best CF ive ever used and verry easy to aplay! But good luck on this one!
da_ashman
07-22-2010, 08:38 PM
Great work so far, love the wheels & that colour should look amazing!!
Entau
07-22-2010, 10:54 PM
thanks for the feed back :smile:
Ferrari TR, this is more like an exercise/practice for me, so even if i make mistake or mess up, it is barely visible :icon16:
pics are download from the internet:
NEW BOTTLE
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/steelnew.jpg
OLD BOTTLE
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/028.jpg
both are different in colors, the one shown on the spoon are NEW, old one look something like this:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Impreza%20WRC%202004/DSCN3712.jpg
(it look brownish)
73superduty, yeap i airbrush it :icon16:
cjsbosox, the front splitter is 0.5mm or 0.0196inch, unfortunately i can't find a thicker rear tire, the stock tire are thick but too narrow:disappoin
Tompidom, the 1/48 CF is from scalemotorsport, i'm worried the 1/24 CF pattern might appear huge on the tiny dashboard :rofl: but i'll test first & see which is better, also i see that you are also doing a 599, maybe you can try on it first & show us how it looks :iceslolan
360spider
07-23-2010, 12:02 AM
Nice work so far, keep it going!
countach79
07-23-2010, 08:08 AM
really nice work so far !!
agamo
07-24-2010, 03:03 PM
Great work!!!
The Front Splitter resulted awesome, you got a great look on the car with those wheels, but I have a question, what about those bolt-holes in the wheels, does the kit include the bolts?
And a question, those round hex from top studio are PE to cut from a fret or are they rubber backed? they look very useful.
Keep it coming!
Entau
07-25-2010, 11:30 PM
alex, countach & ramon thanks :tongue:
ramon, this is how the wheels look like when i got it, no bolts, only 4 air valves were provided
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5538.jpg
the round hex from top studio are rubber backed, no need to cut, also available in hex :iceslolan
http://www.hobbyeasy.com/en/data/48680.html
http://www.hobbyeasy.com/en/data/48679.html
A bit updates:
Original seat, nice but lack of detail
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5833.jpg
so i add some lining using stretch sprue
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5832.jpg
position and glue the bottom first, then align with masking tape
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5837.jpg
apply thin cement along
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5840.jpg
this is the thin cement i'm using, equivalent to tamiya's thin cement
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5838.jpg
there should be extra stitched panel, so i draw line using masking tape
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5834.jpg
cut along the line using modeling knife
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5835.jpg
then i re-scribe the line
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5836.jpg
this is how it looks
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5841.jpg
also i scribe the back where the carbon fiber will be
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5842.jpg
countach79
07-26-2010, 03:47 AM
thats nuts!!:runaround:
Tompidom
07-26-2010, 06:24 AM
Pretty awsome details man!
Scolopendra
07-26-2010, 04:03 PM
I love this work on seats. Definitely a thread worth following.
MidMazar
07-26-2010, 05:10 PM
I like the progress.
luchoteam
07-26-2010, 07:20 PM
Excelent work you are doing!
Keep posting
agamo
07-26-2010, 10:18 PM
Great work on the seats! I liked the method! thanks!
Entau
07-26-2010, 11:16 PM
thanks again :p
i realise i wont be able to paint the button nicely
so i remove it :smokin:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5847.jpg
scratch built it with 0.3mm styrene, kotobukiya parts & top studio round hex again
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5849.jpg
not perfect but better than if i would hand paint it :icon16:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5853.jpg
Tompidom
07-27-2010, 06:51 AM
Woo that is pretty awsome!
TRBJ
07-27-2010, 12:07 PM
very heuge WOW for your interior work man... everythings just wow...
Entau
08-03-2010, 12:00 AM
Tompidom & TRBJ thanks :icon16:
Some progress on the interior, decided to cut out the centre console as detailing will be much easier & i want it to sit on top of the flocking. But it takes me 1 hour & 15 minutes, i thought can be done in 30min, maybe i wasn't using the right tool :banghead:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5854.jpg
then trace the shape with masking tape, transfer to a 0.3mm plastic card, cut and paste on top
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5857.jpg
cut away the plastic excess with knife then sand away with files
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5858.jpg
in total it took me 3 hours plus for the whole process :runaround:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5859.jpg
also drill the speaker holes and add PE, notice the speaker is level with the surface instead just glue on top of it, just adapt Ramon's WIP :iceslolan
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5856.jpg
both seat prime to check for any flaws, still require minor touch up
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5860.jpg
and prime interior to check for any flaws, there is few, so still need touch up, not yet added is the speaker & air-cond vent PE
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5863.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5864.jpg
Entau
08-03-2010, 11:58 PM
Cut off the air-cond vent cover, initially thought to just separate it...
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5876.jpg
but the cover flies over my room, can't find it :banghead:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5877.jpg
no choice but to find replacement, the Wave parts look similar, 4mm but slightly taller, so i just need to sand it down
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5878.jpg
the cover should be on top of the pe
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5879.jpg
luckily it fit :iceslolan
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5880.jpg
i think it's better to paint it first before i glue the PE, so i spray silver, masked then spray matte black mix with a bit of grey
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5882.jpg
glue it using CA glue
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5891.jpg
and this is how it looks
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5894.jpg
store in container, if not sure gone...:icon16:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5895.jpg
Robi J
08-04-2010, 02:47 AM
I like your approach to the kit. There are also some interesting suggestions, thanks.
Very clean as well.
R :)
MidMazar
08-04-2010, 06:01 PM
Ive been using a container like that also, makes life a lot easier. The interior looks really good. Vents are topnotch!
Entau
08-05-2010, 02:57 AM
Robi & Midmazar, thanks :icon16:
Updates:
First i trace out the speaker's grill shape on the dashboard, drill out holes and bevel the shape so that the grill flush with the dashboard.
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5896.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5897.jpg
Using stretch sprue, i apply CA glue from behind
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5898.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5899.jpg
dashboard prime
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5908.jpg
Scratch built window button from tamiya round rod, paint it silver
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5903.jpg
Cut out some left over black decal, faster than spray black mask then spray silver :rofl:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5904.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5906.jpg
Entau
08-06-2010, 01:17 AM
last night i tested the 1/48 scale motorsport carbon fibre on mr color steel base
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5912.jpg
honestly not very visible if look more than 40cm away
only visible on close up
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5910.jpg
then i gloss coat & compound it, not supposed to do this, as the decal not 100% dried & the clear coat haven't cured completedly, it's just for testing
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5922.jpg
the scale looks ok to me, just now i'm headache how to apply the CF nicely, glosscoat, masked and spray the rest semi-gloss without any problems :rofl:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5924.jpg
look quite close compare to my reference
Tompidom
08-06-2010, 05:40 AM
Youl work it out :D
Robi J
08-06-2010, 06:25 AM
I would go deliberately spraying the whole dashboard with Mr. color steel base, making templates for the vents protuberances and the remaining area to be carbonized. Then decaling (the color underneath should forgive small imperfection), clearcoat and polishing. If dash panel lines are deep enough, neat masking of the carbonized area should not be so difficult… then final shot of semi-gloss or matt black.
But you’re for sure skilled to obtain a clean result, even without my suggestion :iceslolan
However, charming progress.
R :)
gionc
08-06-2010, 08:22 AM
Seats are SUPERB!
white_R34
08-06-2010, 05:16 PM
Man this is a real grate subject you have going on here, grate body work man keep it up.
Entau
08-09-2010, 01:12 AM
tompidom, gionc & white_r34: thanks :p
robi j: actually that's exactly what i've plan in my mind, hope it turn out what i want :iceslolan
scratch built the door pocket, sorry for the dark pics :p
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5934.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5933.jpg
i need to use some matte black for the under chassis & wheels, but i'm not too sure to use flat black or semigloss black. so i test it again on the spoon
left: gunze flat black VS right: gunze semigloss black
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5925.jpg
left: gunze semigloss black VS right: gaia black 60% + gunze flat base 20% + steel 20%
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5929.jpg
i might use gunze semigloss black or the gaia mix for the chassis & rear diffuser, the flat black is too flat IMO
Tompidom
08-09-2010, 02:26 AM
Id say go for the semi gloss!
agamo
08-10-2010, 12:02 PM
I would go also for the semi gloss black, that would be close to the real thing.
You did a very good choice on the CF decals pattern size, (here is where I went wrong with mine, LOL) and I'm sure you will get them right.
What I did to ease the process was using two decals, one for the lower section (from the middle of the air vents) and then another for the upper section, don't do it with one decal.
Great job, keep it coming!
Murray Kish
08-10-2010, 03:32 PM
Great work. Saw a 599 on the street the other day. What a fantastic looking car.
Keep up with the great details. Very interesting and impressive. Anyone that has really tried to make small details like that (like the window switch, or the door pocket), knows that getting them so nice and neat is NOT an easy task.
Thanks for the WIP. It will be fun to follow along.
Murray
pharr7226
08-10-2010, 03:37 PM
Very nice work. I really like the modification of the center console. I have to get some of those photo etched blades. They seem to be pretty handy.
Entau
08-10-2010, 11:40 PM
yeah, semigloss it will be :p
tompidom, murray & pharr7226..thanks :rofl:
ramon, thanks for the tips..looks like i've to split it :iceslolan
pharr7226, actually the photo-etch you saw in the vent cutting pic is just to show i cut it, i didn't use it, i use those with tiny saw, they cut nicer but much slower :)
ok, some updates :smokin:
the first door pocket was glue using thin cement, result was not so good because it soften the plastic too much, the 2nd one was glue with super glue, result was much better & easier, i was able to glue it more 'straight', the first one soft too much it bend
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5935.jpg
bottom is the 2nd door pocket
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5936.jpg
then i trace out the carbon fiber shape
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5939.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5940.jpg
done with interior modification & detailing, only require minor 1000 wetsand on some places, should be able to start painting any time soon :cwm27:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5955.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5958.jpg
countach79
08-11-2010, 05:22 AM
really, really sweet build!!
I'm lovin this build!
gtziaf
08-11-2010, 08:29 AM
Awesome, just perfect...
The interior is absolutely amazing...
Scolopendra
08-11-2010, 09:30 AM
Amazing WiP here. Very nice progress so far. Can you, please, tell me what are the units on your cutting mat? Are those inches or centimeters? Just want to understand the size of the 1448 pattern. Thank you.
Entau
08-12-2010, 12:13 AM
countach, gtziaf & scolopendra: many thanks :iceslolan
my cutting mat's unit is 1x1cm for each square box :)
although i really wanted to start painting on my interior, but i guess maybe not, better finish all modification & sanding work before any paint job, my table is super messy :icon16:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5960.jpg
Novitec Rosso's side vent is sightly larger than the stock 599, and the shape also more edgy
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/compare.jpg
so i roughly marked the shape, file the hole to make it bigger and then filled with polyester putty
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5930.jpg
then i carefully sand to get the shape, because it's not easy to get a straight line :banghead:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5931.jpg
still a lot of work is require
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5973.jpg
Exhaust tip also different from stock 599, i tried sanding on the plastic but don't think i can get the result i want, it's too thick and difficult to get it thin
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5965.jpg
so i try this, 4mm metal tube from MSM, although slightly bigger than i want, i think it's better than the plastic
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5961.jpg
so i cut it half, mark the length with tape, file & sand it off, then insert some plastic on the bottom to act as female peg, and slowly file & sand to get the slanted shape
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5962.jpg
here's how it look, but not yet finish...still need some sanding to get it right
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5963.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5964.jpg
and the tricky rear spoiler, i have no idea how the thing looks like, only base on few angle from my reference pics, so the shape might not be correct
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5861.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5862.jpg
sand, sand, sand and more sanding until i got his :rofl:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5969.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5970.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5971.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5972.jpg
comments are welcome :icon16:
UKPonchoMan
08-12-2010, 03:42 AM
There are some reasonable pics showing the rear spoiler here - http://www.novitecuk.com/prod-599-images.html
kans0002
08-12-2010, 11:13 AM
Between you Ramon I swear I am never going to try to build another Ferrari kit again. Hats off to you sir, you are making it all look so easy!
Stuart
Entau
08-12-2010, 12:21 PM
ukponchoman, thanks...but still no top view which i'm looking for...:runaround:
Stuart, don't said that :nono:, i actually gain a lot of tips from ramon's wip, i admit it's no easy...take the air condition vent for example, he separated it but i destroy it :rofl: luckily i have replacement parts and that was already in plan..... i didn't follow exactly, only what i think i'm capable of, so do you :)
Entau
08-16-2010, 03:29 AM
small update on the headlight:
i use some kotobukiya parts again for the headlight, size was correct but too thick :rofl:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5974.jpg
so i attach it to a dremel and thin it down with knife & smoothed with sandpaper 800 grit
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5975-B.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5977.jpg
basicly the original headlight is too short and inaccurate, so i separated it for easier painting and more realistic looking
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5978.jpg
compare to the original, although not much difference, but imperfection masking will show it a lot
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5981.jpg
the transparent headlight cover also doesn't fit, it is protruding from the body contour, so i carefully sand off the transparent part to make it fit & flush with the body
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN5988.jpg
MidMazar
08-16-2010, 06:14 PM
I love the extra detailing your giving this ferrari. Don't stop.
ben_gsr2s
08-19-2010, 01:25 AM
superb!
i seriousy think that you're a pro modeller now.. :sunglasse
don't you have a day job?
it will take me forever to reach that level
Entau
08-19-2010, 02:38 AM
midmazar, thanks :)
ben, car modeling can't make a living in malaysia, i think u should know that :rofl:
i work in advertising, i can do what ever i want when i'm free, but not modeling:icon16:, so most of the free time i browse people's wip and search for reference pics, i'm still learning, not pro, i built very slow, approx 1-2 kit a year :rofl:
Hrcustoms
08-21-2010, 09:06 AM
wow this is beautiful keep it up :smokin:
Entau
08-22-2010, 12:02 AM
small progress on the body, the door handle look fake
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6011.jpg
so i carefully thinned down, using chisel and needle
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6013.jpg
primed, look better now :tongue:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6031.jpg
side vent, after sanding & puttying, some holes & scratches are visible but i decided to cover that after priming, easier to see
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6020.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6021.jpg
after 2 round of priming & careful sanding, this is what i got, looks ok but not perfect :headshake
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6032.jpg
also primed the whole body with mr surfacer 1200
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6030.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6026.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6025.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6024.jpg
UKPonchoMan
08-22-2010, 06:47 AM
Looking really good! What color is it going to be?
Tompidom
08-22-2010, 07:09 AM
Even in primer it is looking fantastic cant wait to see the color!
Entau
08-22-2010, 08:01 AM
intended to use mr color super white iv (156), but i'm not sure is it a match for bianco avus :lol:
Kila2000
08-23-2010, 03:12 AM
How did you apply the Mr Surfacer? I have some but am not sure if it can go through an airbrush
Entau
08-23-2010, 04:03 AM
i use tamiya HG spray-work III 0.3mm airbrush, thinning ratio is 1:2.5 (1 surfacer : 2.5 thinner) yes, its quite thin so i usually need at least 3 coat but the result is smooth :iceslolan
gtziaf
08-23-2010, 04:21 AM
As, I say before great job.
I don't stop to watch it, again and again...
By the way, what thinner are you use for Mr Surfacer? It's tamiya x-20 are suitable?
Thanks for sharing.
Entau
08-23-2010, 04:36 AM
nope, X-20 is enamel thinner, Mr Surfacer is lacquer base, I use Mr. Thinner or Gaia thinner, both are lacquer thinner :cool:
ilferraristarosso
08-27-2010, 03:49 PM
Great work. Seats are awesome and so realistic, i like them.
Max
ANDRE SIQUEIRA
08-30-2010, 09:45 AM
Simply amazing work. You make it sound very easy with this. You can be sure that I'll be accompanying for a day who know how to make one too. Congratulations, keep posting.
Entau
09-03-2010, 12:40 AM
thanks guys for the encouraging words, :icon16:
some updates, but not too progressive as i'm busy with work recently
the rear lips, first trace the shape from the rear diffuser, then cut out from 0.5mm styrene, i draw line to mark the bending line
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6068.jpg
clamp it, blow with hairdryer to soften the plastic so i can bend it without breaking the thin styrene
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6070.jpg
slowly bend it to get the right shape
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6071.jpg
rough shape
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6074.jpg
unfortunately 0.5mm is correct thickness but TOO fragile to work with, and i should NOT use thin cement as it weaken the styrene and break it, actually i break it more than 3 times, i think i've to redo in thicker styrene and slowly thin it down :smokin:
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6078.jpg
frustrated, i continue other easier parts, the side vent is too shallow if looked from the side, so i add some styrene sheet to make it deeper
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6091.jpg
reinforce inside, also it's easier for me to position & glue the mesh later
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6092.jpg
and the rear spoiler is almost done, but i felt the shape is incorrect and too small
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6084.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6085.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6086.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6087.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6088.jpg
http://i203.photobucket.com/albums/aa155/Entau/ALL%20WIP/Novitec%20Rosso%20599%20GTB/DSCN6089.jpg
the spoiler bracket is made from leftover sprue runner, as i felt the styrene sheet that i had is too soft, first i drill holes, then slowly sand to get the right shape, then i cut it out and slowly sand to get the correct size and fitting, very difficult to get everything glue symmetrically if there's a slight dislocation, as you can see, the position i glue is not centralise and slightly towards the right side.
comments are welcome :tongue:
