1999:engine knock
afrederic2
07-10-2010, 05:44 PM
99 3.1, last year i replaced top end gaskets, new waterpump, alternator, plugs, temp sensor, starter, radiator cap. anyways it knocks now, i thinks its a piston slapping, it does it all the time any rpms. but after some research i think it could be spark knock, there are no dtcs. any one know how to tell the difference between piston slap and sprk knock?
maxwedge
07-10-2010, 07:00 PM
Piston slap goes away after the engine warms a little and you would normally have some degree of this from new. Someone knowledgable has to listen to this to determine if this is a bearing noise, if the engine had been run with coolant in the oil this can damage the bearings.
afrederic2
07-13-2010, 09:13 PM
ya it sounds like that but never goes away, like i fried a ring or something, but wouldnt the knock sensor set off a dtc if its knocking? it definetly sounds like a piston is slappin the cylinder wall
jyount
07-14-2010, 04:44 PM
are you sure you don't have a lifter knocking? If you had piston slap it should go away. Deep bearing knock and you should be able to tell it is bearing knock.
afrederic2
07-14-2010, 07:03 PM
i guess it could be, but its pretty loud and hollow sounding, how would i go about testing it? its coming from the top more, more by the fire wall.
bcopeland
07-18-2010, 12:02 PM
My guess is the lifter has come loose or it is sitting in a stripped out hole. You might need to look at it again. Whenever I had that sound, it was a loose rocker.
