gas gauge
jericho999
05-11-2003, 07:55 PM
my gas gauge on my crx doesnt work, has anyone had this prb and if so how did u fix it
thanks
crxlvr
05-11-2003, 09:07 PM
does your temp guage work?
cuz if it does, than you just have some plugs loose, or the wires are cut, you need to trace em.
branman_crx_guy
05-11-2003, 09:39 PM
Also check your fuses, i had the same problem with my old rex and it was just a loose fuse.
jericho999
05-11-2003, 10:41 PM
ya the temp gauge works, what fuse would it be?
branman_crx_guy
05-11-2003, 10:45 PM
i dont remember, i know its a red one, just check the fuse panel it should tell u.
EF You
05-12-2003, 12:32 AM
if none of the above fix it, then you needa take out the fuel sending unit and check the resistance levels on it haynes has the specs.
jericho999
05-13-2003, 07:42 PM
how do i check the resistance levels
crxlvr
05-13-2003, 09:17 PM
you'll need an ohm-meter.
