ID 91-96 Turbo Transmissions
PAHAKA
07-07-2010, 01:16 PM
Help me folks. I have two 91-96 300ZX turbo transmissions with no ID tags. Previous forum research has told that the TT flywheel is 4MM larger diameter and the bellhousing is clearanced accordingly. Also, that the starter mounting boss is different. In what way? Thicker?, to set the starter slightly outboard? I need some specs, TT bellhousing inside diameter, starter mount thickness or height from exterior of bellhousing. How can I confirm that these are TTs?:banghead:
txq45
07-23-2010, 12:28 PM
From your questions it looks like your trying to change from a NA to a TT..
Just change the bell housing from one to the other and it will work.
