99 Neon Sport not starting
ecamc
07-07-2010, 11:03 AM
My son called yesterday and said he tried to start his car, and turned the key, and all the lights, chimes, radio turned on, but he turned the ignition and NOTHING. No trying to turn over or anything.
He tried a couple more times, sometimes he gets lights, chimes, other times, nothing. Had him try today with a different key with the same results. He is eight hours away, so it makes it pretty difficult for me to troubleshoot from here :banghead:
Any ideas?
jdl
07-07-2010, 11:34 AM
If this is an automatic, did he try cranking in neutral? Have him turn on the headlamps then turn the key to crank, see if there is any reaction from the headlamps, do they dim-- go out-- stay bright no reaction? If they stay bright, sounds like an open circuit to the starter.
Also, he could use a jumper at the starter relay. Make sure the tranny is in park or neutral and a functional e-brake is set. Key in the on position, on is where the dash lites come on, pull the starter relay, use jumper wire between terminals 30 and 27, where the relay plugs in, the starter should crank. Don't leave the jumper hooked up more then a few seconds. Don't know how experienced the person is as far as working on vehicles, if he isn't comfortable with this testing, then don't test.
