help passing emmissions!
thecone137
05-06-2003, 10:19 AM
i have an acura integra ls 1995(i\h\e) which i plan on turbocharging very shortly(revhard stage II). I know for a fact that my car will not pass emissions once i get my turbo, so my question to you all is; how can i get my car to pass once i get my turbo??? I know its posssible , but im new to this and neeed helpp! thx..
PWMAN
05-06-2003, 10:28 AM
What does putting a turbo kit on do to make it not pass?
Self
05-06-2003, 12:26 PM
Why wouldn't it pass? Unless your info there is wrong and you're actually in California or something...Other than that you should have no probs passing.
thecone137
05-06-2003, 09:04 PM
from what i know, this kit is not carb legal. could I be mistaken? I took my car to the inspection station a couple days ago and failed with just my basic mods (i\h\e and high-flow cat). with more air being pushed through how can I possibly expect to pass?
killah_xft
05-07-2003, 04:48 AM
just put your stock exhaust, and catalytic converter back on, and take the test, you should pass, the header, and intake you should be able to keep on it...
killah_xft
05-07-2003, 04:52 AM
and then when you pass the test and get your sticker, or whatever it is, put your catback, and hi flow back on... and DAMN! am I glad Maine does'nt have emissions regulations... otherwise these fishermen freaks would have to trade in their 8cyl gas guzzlers, that reek of unburnt fuel.. and I won't have to worry about my LEV (Low Emissions Vehicle) accord. My inspection consists of lights, turn signals, brakes, wipers, and if it can drive into the garage...
thecone137
05-07-2003, 11:51 AM
switching to my normal cat converter and exhaust sounds good , but will i be able to pull that trick off once i get my turbo put on??
PWMAN
05-07-2003, 03:12 PM
The turbo kit's downpipe should end up it the stock location to bolt up to the stock cat.
And isn't CARB legal a california thing? I thought thats what the C is for - California Air something something.???
thecone137
05-07-2003, 04:20 PM
i apologize to everyone kind enough to repsond for my ignorance. What I am referring to is not C.A.R.B. legallity ,but the ability for the car to pass emissions test for inspection. new jersey requires it and i need that sticker to keep my car registered. i do not know anyone who can get me a sticker , so what are my other options????/
killah_xft
05-08-2003, 05:33 AM
slip the inspector a bill ( like $20) usually they just check everything else, and look the other way.. but be wary... but changing to your stock cat should work, and it's not that hard... just 4 bolts I think..
