95 chevy astro van 4.3 vin w
garybllrdr
06-09-2010, 02:49 PM
van surges and dies after warmed up.
new egr valve
new tps sensor
new coolant temp sensor and switch
new map sensor
fuel pressure 62 psi at start and running
new ignition module old failed test
new fuel filter
fuel in oil
new plugs wires
new plugs oem for all above
any sugestions as to what this might be caused by? after stalls sometimes wont start till sits for awhile. no codes in computer runs and idles great when cold
HELP thank you:runaround:
new egr valve
new tps sensor
new map sensor
new fuel filter
fuel in oil
new plugs wires
old_master
06-10-2010, 05:50 PM
Fuel in the oil could mean excessive leakdown. Check fuel pressure and leakdown first. Key on, engine off and cold, fuel pump running; pressure must be 58psi to 64psi and must remain above 53psi for 3 to 5 minutes after the fuel pump shuts off. Post your results.
garybllrdr
06-11-2010, 08:30 AM
Turned out to be a leaking Fuel injector/ spider replaced changed oil van runs like new no problems now
old_master
06-11-2010, 04:36 PM
Leaking injectors will cause leakdown to be excessive. Good job, glad you got her fixed, and thanks for posting back.
