1997 Pontiac Bonneville Cranks, No Start
bonneman
06-08-2010, 08:48 AM
The other day I backed my car up to wash it and after I finished I tried to start it up, with no luck. I checked the fuel pump pressure, which was 0 psi. So I changed the fuel pump along with the fuel filter. After changing the pump I checked the fuel pressure, and still 0 psi. So could this problem have to do with the electrical system? Also, I've recently replaced the spark plugs and all of those are firing. Any ideas? Thanks.
maxwedge
06-08-2010, 03:58 PM
Do you have 12v to the pump?
bonneman
06-09-2010, 04:51 PM
I found out why it wasn't starting, the little gray box that connects the wiring harness one of the sockets was blown out so I changed it off of another fuel pump I had. The car finally started, but there is only 20 psi when I check it when it is running. 45 psi is the norm right? Don't know what else to check.
