Wet trunk
MickBurke
05-03-2003, 10:36 PM
My 92 Accord has a wet trunk when it rains. My mechanic suggested that I may have a leak around the tail light lenses, and I did see a good bit of moisture when I pulled one of the bolts to get to a ground for the audio system. My questions are; does this sound right (as the acutal puddle that I found was next to the wheel well) and if so do I just put some silicon around the lense or is there an actual gasket for them? Thanks!
Mick
Mick
lorunner
05-04-2003, 11:02 AM
there is an actual gasket and my sugjestion is if you are going to replace one replace them all, they will leak sooner or later. also if you have an EX with a sunroof you might want to check the roof drains they clog sometimes to and they are also in the trunk.
accordztech
05-04-2003, 11:18 PM
usually it can be the lenses. i put silicone in mine cause it was always wet. now no more leaks =)
Melt
05-04-2003, 11:40 PM
hmm, the tails! ... on my moms accord my dad has had them reseal the rear window twice now and it still leaks! Ill be sure to get some of those bad boys.
dutchaccord
05-05-2003, 11:50 AM
if the tails arn't leaking, check seal underneath rear window inside trunk......
Stefan
Stefan
accordztech
05-05-2003, 06:05 PM
dutchaccord: can you tell me what mods are those on your car? drop, body kit, rims etc? sweet looking!!
dutchaccord
05-08-2003, 03:42 PM
check ur pm
check ur pm
002star
05-11-2003, 09:55 PM
I have that same problem on my car. Did you figure out how to fix that, my dad told me to buy new ones. But I thought that was really expensive so i screw it. Anyway tell me if you got that fixed Thanks.
hondaman-iac
05-11-2003, 10:10 PM
i had the same problem, but only if i was driving the car while raining. it turned out it was a bad sealing between the quarter panels and the strut tower. not that is fixed and no more water inside
002star
05-13-2003, 10:58 PM
You said that it happened when you drive the car during the rain? Makes sense 'cept that mine does it when it sits in the driveway. I checked that seals and they look good. I don't know what else to do? Any answers? Thanks
abstract821
07-07-2003, 09:45 AM
I've got a 92 and the same problem. Well, had. Mine did it if it was sitting or if I was driving it. I just put in more seals (that rubber lining) and it hasn't done it since.....
