TPS at 10% when closed
rides2fix
05-25-2010, 09:50 AM
I am working on a 2004 Mustang with a 3.9L V6 that has random and specific cylinder misfire codes. I notice with my scan tool that the TPS is not reading 0% when the throttle is closed; is this normal? My thought is that this may be contributing to the misfires and I should reset it to read 0%. Does anyone have any thoughts on this? The engine has low mileage, around 45,000.
Thanks, John
Davescort97
05-25-2010, 11:00 AM
Hi John. It is a normal TPS reading. I have a scan-guage on my Escort. The TPS on it is 13 at idle and 92 at full throttle. I would be looking else-where for the misfire codes.
Have you looked into vacuum leaks. That could cause a misfire. Many times have I seen a recurring misfire condition after replacing all the ignition components. Dave
Blue)(Fusion
05-25-2010, 11:39 AM
Clean the MAF sensor, check for vacuum leaks, check the spark plugs and COPs, and check fuel pressure.
rides2fix
05-25-2010, 09:40 PM
Thanks for the input. I have just started troubleshooting this and wanted to clear up the TPS reading before replacing anything. I haven't detected any vacuum leaks and since the misfires reportedly happen during rainy or damp weather I am looking towards the ign wires, but don't see anything obvious there either. Will probably replace the plugs and wires and wait to see what happens.
Thanks again,
John
