key stuck in ignition
seahorse
05-22-2010, 08:35 AM
Hi, my husband has an '07 Cobalt and for the last month when he parks and goes to remove the key he can't, it won't turn back all the way to remove it. He has to sit there for a minute, sometimes two, before he hears a click and then he can turn the key back the rest of the way and pull it out.
Advice please?
Thank you! Have a wonderful weekend.
Advice please?
rhandwor
05-26-2010, 05:07 AM
Call the dealer and check if this is covered under warranty. Try wiggling the steering wheel and check if it releases.
You may need a new one.
seahorse
05-31-2010, 01:59 PM
he's wiggled the steering wheel pretty good at times, and he's turned the key forward and ran through the gears and back to park, but that doesn't help either. It's got over 52k miles on it... I'll email the dealer... thanks
hinton08
06-25-2010, 04:26 PM
The tumblers in the ignition lock cylinder have dropped down and lock the key in there and you cant get it out until you wiggle the tumblers back into place. You need to either replace the ignition lock cylinder or take it to the dealer and have them rebuild the lock cylinder. its pretty common on these models.
seahorse
06-25-2010, 04:59 PM
thanks. We brought it in and they replaced the shifter control. It was something electrical and worn out I believe. Haven't had a problem since!
hinton08
06-25-2010, 05:09 PM
ok good to hear
